Rhino8, 360 environment (Raytraced)
Hi Everyone,
How to apply changes in 360 environment?
It seems that in Rhino 8 doesn’t accept new values such as saturation parameter.
In the example I show, you should see the map in grayscale (in Rhino7 it works).
Thanks
I probably forgot to hook up the texture adjustment node for environments.
RH-81386 Textures in rhino environment aren’t observing adjustments
Thank you for your prompt response :wink:
I’m glad it wasn’t just me. I was driving myself loopy, just gave up in the end, did it in GIMP and then brought it back in.
RH-81386 is fixed in Rhino 8 Service Release 7 Release Candidate
