just installed from scratch Rhino7 and default linetypes in linetype options panel don’t show correctly.
Hello - can you please run SystemInfo in Rhino and copy/paste the results here?
Here it is.
Rhino 7 SR2 2021-1-21 (Rhino 7, 7.2.21021.07001, Git hash:master @ 96ff97351fbdf5d2acdeaf781aea1577f2ff60f7)
License type: Commerciale, build 2021-01-21
License details: Cloud Zoo
Windows 10.0.19042 SR0.0 or greater (Physical RAM: 7.8Gb)
Computer platform: LAPTOP - Plugged in [70% battery remaining]
Primary display: Intel® UHD Graphics 620 (Intel) Memory: 1GB, Driver date: 12-23-2020 (M-D-Y).
- Windows Main Display attached to adapter port #1
Primary OpenGL: NVIDIA GeForce MX150 (NVidia) Memory: 2GB, Driver date: 12-31-2020 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 461.09
> Integrated acclerated graphics device (shares primary device ports)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 8x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 12-31-2020
Driver Version: 27.21.14.6109
Z-Buffer depth: 24 bits
Total Video Memory: 2 GB
C:\ProgramData\McNeel\Rhinoceros\6.0\Plug-ins\Twinmotion Direct Link 2020.2 (e24ee14a-9514-47da-8fe6-f6e61b20160e)\Twinmotion Direct Link 2020.rhp “Twinmotion Direct Link 2020” 1.0.6.0
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.2.21021.7001
C:\Program Files\Rhino 7\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 7\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 7\Plug-ins\IdleProcessor.rhp “IdleProcessor”
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.2.21021.7001
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.2.21021.7001
C:\Program Files\Rhino 7\Plug-ins\Alerter.rhp “Alerter”
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.2.21021.7001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.2.21021.7001
Hm - it is hard to imagine the TwinMotion plug-in being at fault here but just ot make sure, please disable that plug-in in Options > PlugIns page and then close and re-open Rhino - is that any better?
You were right, it makes no difference.
I just updated to 7.3 but the problem is still there.
@lowell - do you have an idea what might cause this?
back on this.
I’ve noticed that if I click i.e. on the “border” linetype I get the correct pattern, in mm in this case:
Then, if I switch to inches, this is what I get:
Back to mm and this is the result:
Inches again:
This just switching the units type.
Wierd…
Hello - I do see slightly odd numbers here - not sure yet why that is - but they stay when switching back and forth - is the problem you see in any file? If not, can you please post a simple file that shows it?
Yes, any file: starting from scratch, opening old files which used to work correctly on Rhino6, …
Whoa! This is magic, now it works flawlessly.
Don’t know what it does, but that’s it. Thank you!
Well, not any good kind of magic really, it shuts off the dialog code that is supposed to magically work better…
So, even magic has its limits… 8^)
RH-62919 is fixed in the latest Rhino 7 Service Release Candidate
Just updated to 7.4.21067.13001, re-enabled UseEtoLinetypePage and now it works. Great!
