Command dialog setting - Use command options dialog as separated window with sidebar hidden is not working. Command dialog is still attached to sidebar nad Themes settings are reset after restart.
Thanks. Seems to be related to latest Release Candidate, 7.2 works as expected. Solution: uninstall Rhino with all preferences and caches and download 7.2 packagage
I noticed this yesterday as well. On Mac V7.3 many of the settings can’t be changed.
I did the same as @mlkplk - reverted to V7.2
Hi, I’m trying to reproduce this issue but so far no luck, I tested 7.2 and a 7.3 service release candidate. I also tested an internal 7.4 build all on macOS 11.1. Can you run the command SystemInfo in Rhino 7 please and return that text file here? Thanks. Also, did you make a new document after the change in Themes?
