Hi all,
I have one surface in the attached file and rhino3dm thinks that the surface is not planar. Is this a bug?
import rhino3dm
path = r"C:\Users\devan\Desktop\test.3dm"
file_3dm = rhino3dm.File3dm.Read(path)
for obj in file_3dm.Objects:
print(obj.Geometry.Surfaces[0].IsPlanar())
Output
False
test.3dm (42.7 KB)
dale
(Dale Fugier)
December 8, 2020, 11:56pm
#2
Hi @Devang_Chauhan ,
How about this?
import rhino3dm
model = rhino3dm.File3dm.Read('/Users/Dale/Downloads/test.3dm')
tol = model.Settings.ModelAbsoluteTolerance
geometry = model.Objects[0].Geometry
if isinstance(geometry, rhino3dm.Brep):
print(geometry.Surfaces[0].IsPlanar(tol))
– Dale
Wow! Thanks for this quick help. I should not have missed that.
Hi @dale ,
Can you please try the surface in the attached file? It does not work even after using tolerance.
test.3dm (43.7 KB)
dale
(Dale Fugier)
December 9, 2020, 12:27am
#5
Although the surface appears planar, it is not (at least within the model’s absolute tolerance).
– Dale
Learned something new today. Thank you for the help!
