Lionel
(Lionel)
March 13, 2023, 1:22pm
1
Hi all
My Rhino is stuck on SR18 and when i go to check for new updates on the help menu the whole panel is greyed out and nothing is clickable. The box in that tab reads “McNeel update service is unavailable” even though it is running in ‘Services’ on Windows.
Have rummaged online for a solution but haven’t had much luck.
Anyone know what to do about this?
Japhy
(Japhy)
March 13, 2023, 1:23pm
2
Lionel
(Lionel)
March 13, 2023, 1:33pm
3
I’ve just re-installed and it is now on SR27 but that update tab is still showing the same unavailable message plus greyed out buttons.
Any way to activate auto updates?
Japhy
(Japhy)
March 13, 2023, 1:36pm
4
Go to Document Properties or type in Options into the command line.
Japhy
(Japhy)
March 13, 2023, 1:42pm
7
Is your update services running?
In Windows Services, is the McNeel Update service running?
[image]
Japhy
(Japhy)
March 13, 2023, 1:52pm
9
Are you running any anti-virus software/ window user account control that would block the required port? or the registry entry from being set?
I see several possible solutions from previously reported issues.
Lionel
(Lionel)
March 13, 2023, 2:15pm
10
Not to my knowledge and I’ve looked for the registry and cannot seem to find it anywhere within the Mcneel folders.
Japhy
(Japhy)
March 13, 2023, 2:16pm
11
Lets make sure your install is OK.
close Rhino
go to add/remove programs and Modify the install and select the Repair option. This will require a reboot.
The key is located here, please check after the Repair install.
Lionel
(Lionel)
March 13, 2023, 2:31pm
12
Ok the registry edit seems to have allowed me to click on buttons in the update tab but I still have “Service is unavailable” in the message box
Japhy
(Japhy)
March 13, 2023, 2:36pm
13
Progress! Close Rhino and go back to Windows Services and see if McNeel Update Service is Running. If so go ahead and stop it and restart it. Then restart Rhino.
Lionel
(Lionel)
March 13, 2023, 2:39pm
14
That did the trick! Thank you very much Japhy much appreciated.
