Trying to make an plugin Using VB.Net in VS 2008
Need the help file where i can get the examples and syntax of each and every command.
I got this cod on http://wiki.mcneel.com/developer/rhinocommonsamples/addcircle
Public Shared Function AddCircle(ByVal doc As Rhino.RhinoDoc) As Rhino.Commands.Result
Dim center As New Rhino.Geometry.Point3d(0, 0, 0)
Const radius As Double = 10.0
Dim c As New Rhino.Geometry.Circle(center, radius)
If doc.Objects.AddCircle© <> Guid.Empty Then
doc.Views.Redraw()
Return Rhino.Commands.Result.Success
End If
Return Rhino.Commands.Result.Failure
End Function
but It shows me Rhino.RhinoDoc type not defined…
Do i need to import something ??
I have defined following imports in the project
Imports RMA.Rhino
Imports RMA.OpenNURBS
Imports RMA.Rhino.RhUtil
Imports Rhino4
Hi there,
For what Rhino are you trying to create a plugin?
If I open the developer part it says (http://wiki.mcneel.com/developer/rhinocommon):
Visual Studio 2010, 2012 and 2013, both in C# and Vb.Net, and included
in Ultimate, Professional, Premium, C# Express, Vb Express and Windows
Desktop Express where available.
You need to add RhinoCommon.dll to the project to get Rhino.RhinoDoc defined.
Where will i get RhinoCommon.dll ???
The x86 version is located: C:\Program Files (x86)\Rhinoceros 5\System\RhinoCommon.dll
and the x64 version: C:\Program Files\Rhinoceros 5 (64-bit)\System\RhinoCommon.dll
it automaticly updates when you update your rhino.
I am using Rhino 4
The example that you posted is created with RhinoCommon. I think rhino4 does not know RhinoCommon.
You can see examples for Rhino4 here:
Thnx Jordy.
Is there any reference where i can get the reference for all commands. like adding layer. adding circle. placing point on curves. and many more for rhino4
