Edit Code Site Developer
https://developer.rhino3d.com/api/rhinocommon/examples/addcircle
import Rhino
import scriptcontext
import System.Guid
def AddCircle():
    center = Rhino.Geometry.Point3d(0, 0, 0)
    radius = 10.0
    c = Rhino.Geometry.Circle(center, radius)
    if scriptcontext.doc.Objects.AddCircle(c)!=System.Guid.Empty:
        scriptcontext.doc.Views.Redraw()
        return Rhino.Commands.Result.Success
    return Rhino.Commands.Result.Failure
if __name__=="__main__":
    AddCircle()
immagine
It has happened several times that some parts of the code don’t work. . .
Wouldn’t it be advisable to be able to log in like in the forum and directly modify the code?
(and the change is confirmed after team checking)
Yes, there will probably be a fair amount of samples that worked in Py2 that don’t in Py3…
instead of
import System.Guid
use
from System import Guid
It is not a question of form, and generally, at the end of various other checks, I come to the conclusion that the copied code may contain minimal inconsistencies. Personally, several of these situations have happened to me which I have not reported due to their minimal importance, the suggestion was to make the changes without clogging up the forum.
I think I can get that fixed in the sample. Thanks for reporting it. I have gone thru a lot of the documentation. But there are many Samples out there that still probably have a problem.
yes, over time I found several, I didn’t know if you would appreciate the report,
but if you’re interested I’ll let you know what I find. . .
If you don’t want to post them on the forum, you can create a list and send it directly to tech support.
