On Layout views in Rhino V8, the Zoom Extents and the Zoom Extents All Viewports buttons shrink the objects to a very small part of the screen.
Regards, Garry.
Regards, Garry.
Hi Garry -
I can’t reproduce this issue here. Can you post (or upload) your file?
@wim I tried the model that I sent to you yesterday, and it is OK. After some head scratching, I discovered that the problem is triggered by the Block definition on the layout pages. I have attached a version of yesterday’s model with the block definition reinstated. It is OK in V6 and V7, but V8 shows the zooming problem.
Regards, Garry.
HouseRemodel28ZoomExtents.3dm (4.5 MB)
I think you must have a lot of linked blocks. When I open this file to try to reproduce, this is all I see:
G’day Brian. That is all that is in the model that I uploaded. Switch to the Layout page and click ZoomExtents. That should demonstrate the problem.
Regards, Garry.
Thanks, I logged this as RH-78833 ZoomExtents in Layout wrong
G’day Brian. I cannot see RH-78833 in the tracker. Is it still logged for attention?
The problem still exists in Version 8 SR4 (8.4.24030.15001, 2024-01-30).
Regards, Garry.
Yes, it’s still there. I just marked it as readable publicly.
All OK now. Thank you to all involved.
Regards, Garry.
