The code below is from Rhino IronPython Help and userinterface.py (V6), with ShowOpenDialog in place of ShowDialog in the latter.
When the script is run in V5, multiple files can be selected and fd.FileNames contains all the paths and file names.
When run in V6, only a single file can be selected, but fd.FileNames contains an empty array.
Thank you,
Steve
import Rhino
def openFileNames(title=None, filter=None, folder=None, filename=None, extension=None):
fd = Rhino.UI.OpenFileDialog()
if title: fd.Title = title
if filter: fd.Filter = filter
if folder: fd.InitialDirectory = folder
if filename: fd.FileName = filename
if extension: fd.DefaultExt = extension
fd.MultiSelect = True
if fd.ShowOpenDialog(): return fd.FileNames
return []
filenames = openFileNames("Open", "Text Files (*.txt)|*.txt|All Files (*.*)|*.*||")
for filename in filenames: print filename
