Under OSX when I use
var dialog = new Rhino.UI.OpenFileDialog
with
dialog.MultiSelect = true;
it does only single selection. Under Windows it allows the selection of more files.
Márton
with
Márton
Hi @marton.parlagh,
Use Eto:
var fd = new Eto.Forms.OpenFileDialog
MultiSelect = true,
Title = "Select Multiple"
var rhino_file_filter = new Eto.Forms.FileFilter("Rhino 3D Models", ".3dm");
fd.Filters.Add(rhino_file_filter);
var result = fd.ShowDialog(Rhino.UI.RhinoEtoApp.MainWindow);
if (result != Eto.Forms.DialogResult.Ok)
return Result.Cancel;
foreach (var filename in fd.Filenames)
RhinoApp.WriteLine(filename);
return Result.Success;
– Dale
Thanks, it really works under OSX too:)
Márton
