Hello , I am looking for the best way to transfer files from Rhino 5 to Solidworks .
Do I join up all my surfaces or leave them as individual surfaces ?
Anthony
Hi Anthony - in general export solids (all joined up) to SW. Use STEP (the most common, I’d say) IGES (Solidworks Solids flavor) or Rhino V4 formats to get to SW.
Thanks Pascal , will the file be editable once in solidworks ?
Hi Anthony - that depends - it will be editable in that you should be able to add features, but it will not automatically have a feature-tree of its own. SWs Feature Recognition tool can establish a feature tree in some cases. I’d always run diagnostics on the import - often there are a few or a lot of things that SW does not like - it does depend on how tightly modeled the thing is in Rhino as well - but SW can often fix the things it does not like from Diagnostics.
Hey Pascal ,I’m thinking like, things to adjust volumes or once a mold is made if we need to make some adjustments since it will be made on the solid works file since I had it off from Rhino. Even things like draft angles.
I am using Rhino to capture the look and direction of the design. Trying to be as tight as possible but have no experience with setting up draft angles . I’m sure that there is a feature in rhino , for instance if I do cavity on my model’s surface, what that radius or angle should be .
Anthony
Hi Anthony - the most common, I think. approach to using SW and Rhino together is to make the more difficult, styled, swoopy surfaces in Rhino and do the detailing in SW. Here’s a nice clip from Phil Cook at Simply Rhino that gives a good idea how things can work. This does not address your specific questions but it may give you an idea how to proceed.
@Shap3 - looks like the clip did not make it the first time - here it is.
Coffee…
In Rhino, DraftAngleAnalyisis
and CurvatureAnalysis
set to Max & Min Radius may be of use, judging from your comments.
Was the clip attached?
Jumping in here to say " click on video " should work fine. —Mark
Hi Pascal , I seem to be having a funny thing happening , every time I was to move an object with the Gimball on , when I grab a arrow on the Gimball, it quickly jumps to that position . I can’t seem to drag slowly , but it did at one time .
I must have hit a button somewhere . Is there a present for the Gimball?
Thanks for your help
Anthony
Hi Anthony - check the GumballSettings
and make sure it is set to ‘smooth’ and not ‘snappy’. (SnappyGumball=Off
Thanks ,
(post withdrawn by author, will be automatically deleted in 24 hours unless flagged)
Okay we get it, no need to spam every thread in the history of Rhino support where anyone ever mentioned Solidworks or Creo.
