Rhino to INVENTOR edit impossible?
Inventor accepts 3dm files, but i can’t rotate or do anything with it ?
Aircraft 2.1 rework.3dm (2.2 MB)
You might try exporting it to STEP and opening that in Inventor.
Inventor is also a “solid modeler” whereas Rhino is a Surface modeler.
You might get better results if your Rhino objects were closed solid polysurfaces before exporting.
Any luck?
Hi Bilan - does Inventor have any kind offeature recognition tools ? That can get some, at least, depending on the details, editablity in SolidWorks, for example.
