Rhino rendering doesn’t seem to work. What’s the mistake?
The plugins are activated. But in the end I only get a black image.
This requires more context.
What isn’t working? Is there an error? is it making black screens?
Can you post your SystemInfo command result here?
Cheers.
System Info:
Rhino 7 SR36 2023-12-12 (Rhino 7, 7.36.23346.16351, Git hash:master @ 11a364321297eb8cdb34405a3308d8911f58706d)
License type: Studentenlizenz, Build 2023-12-12
License details: Cloud Zoo
Windows 10 (10.0.19045 SR0.0) or greater (Physical RAM: 32Gb)
Computer platform: LAPTOP - Plugged in [96% battery remaining]
Primary display and OpenGL: NVIDIA GeForce RTX 3080 Laptop GPU (NVidia) Memory: 16GB, Driver date: 3-12-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 551.86
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 3-12-2024
Driver Version: 31.0.15.5186
Z-Buffer depth: 24 bits
Total Video Memory: 16 GB
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.36.23346.16351
C:\Program Files\Rhino 7\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 7\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 7\Plug-ins\AnimationTools.rhp “AnimationsWerkzeuge”
C:\Program Files\Rhino 7\Plug-ins\IdleProcessor.rhp “LeerlaufProzessor”
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.36.23346.16351
C:\Program Files\Rhino 7\Plug-ins\RhinoRender.rhp “Vorgänger Rhino-Renderer”
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.36.23346.16351
C:\Program Files\Rhino 7\Plug-ins\Alerter.rhp “Alarm”
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.36.23346.16351
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.36.23346.16351
C:\Program Files\Rhino 7\Plug-ins\NamedPositions.rhp “Benannte Position”
C:\Program Files\Rhino 7\Plug-ins\RhinoBonusTools.rhp “Rhino Bonus-Werkzeuge”
Goodo.
What is your lighting like in the render and the settings?
Also, is there a minimum example you can upload, with just your room, lighting, and maybe a single chair?
Something like that? Can you explain to me how the lights work? I didn’t define any additional lights because I thought the sky light/sunlight in the render settings under Lighting was enough.
I just rendered the room with chair. And it worked. But why are the window panes so dark? Almost no light penetrates through.
Okay so just keep in mind that rendering is a completely different industry, completely different vocation, from modeling, and as such at least as big a job to learn to do decently.
What are your glass window objects? They need to have inner and outer surfaces for ‘glass’ materials to work right. What is your lighting? The basic global environment is just gonna provide diffuse overall lighting, you’re not going to get any beams of light coming through the windows.
Also, it is useful to use the Rhino glass material and leave the color very light - just white maybe to get started with.
