Rhino Python 101 question as I’m new to both and haven’t used Rhino / Python PC version. Following along with the chapters in RhinoPythonPrimerRev3.pdf on p.34, there is a small program that uses both “prompt” and “print” in the following lines:
prompt = “What is your {0}th most favorite thing?”.format(count+1)
print “Your”, len(things)+1, “favorite things are:”
I don’t get any errors when running this file in Rhino, but I never see any print or prompt text anywhere. No dialog box and nothing in the bottom left corner of the window. Is this because the built-in console window isn’t up and running for the mac version yet, or am I doing something wrong?
I’ve tried toggling the preference > legacy > Use text field for command line and command options but neither reveals the prompt or print results.
rather, when the program uses the prompt variable here:
answer = rs.GetString(prompt)
a dialog box should be popping up, but it doesn’t seem to.
Here’s the whole script:
import rhinoscriptsyntax as rs defmyfavoritethings():
things = []
while True:
count = len(things)
prompt = "What is your {0}th most favorite thing?".format(count+1)
if len(things)==0:
prompt = "What is your most favorite thing?"
elif count==1:
prompt = "What is your second most favorite thing?"
elif count==2:
prompt = "What is your third most favourite thing?"
if answer is None: break
things.append(answer)
if len(things)==0: return
print "Your", len(things)+1, "favorite things are:"
for i,thing in enumerate(things): print i+1, ".", thing
Your script needs a little bit of formatting to work correctly. Here’s a version that works for me:
def myfavoritethings():
things = []
while True:
count = len(things)
if len(things)==0:
elif count==1:
elif count==2:
myfavoritethings()
Also note that I added a call to myfavoritethings() at the end of the script.
When I run this script, I get this dialog:
At the end, the output goes to the status line at the lower left corner. Since there are multiple lines of output, use Window > Show Command History in the Rhino menu to see all the output.
