Rhino on macOS Sequoia anybody?
somehow i managed to skip the previous major release completely, mainly because Apple got really good at making things bad which immensely stunted my trust, but i am now ready to emerge with Sequoia and before i do that,
has anybody tried it with Rhino etc.?
I’m not seeing any issues with the actual functioning of the app - but Finder is lacking previews for all my Rhino files at this point.
I’m regularly getting the spinning wheel of death on initial load (minutes to load) and then when I navigate away from the Rhino window and back to it.
Sequoia 15.1, Macbook Pro M1 Max, 32GB
before the update to 15.1 did you have any issues? i am on 15.0 now and besides the silly thumbnails which i could not care less about (ok not that silly but also not that crucial) everything seems to work alright.
I upgraded from Sonoma. I would have issues occasionally. Now, the app is mostly unusable. Tried deleting and reinstalling, no improvements. 5+ min load times, locks up in the app at points and eventually has to be killed.
Things appear to be working better now. It seems that my issue may have been related to Google Drive. I’m not sure if it was trying to hold files open or blocking files, but once I killed that, my Rhino operations/times seemed to return to normal.
ok good to know, i was holding off with that update now thanks for letting me know.
Hi, does anyone at mcneel can confirm rhino 8 is fully compatible with macos sequoia ?
Macos 15.2 will be out soon, and I would like to upgrade, but don’t want to have rhino not working.
Hope I don’t have to wait for rhino 9 :thinking:
Hi Yann -
I’ve been running Rhino 8 on macOS 15.0.1 for a while without issues.
Sequoia 15.1 installed on 2013 Mac pro 6.1 can’t load or draw anything without it crashing.
maybe that is due to Sequoia not being officially supported by apple on your computer? i have no experience with OpenCore or whatnot, so i can not comment on that but hightly unlikely that a computer that is 12 years old with patched mac os will run well with v8.
you could try TestMetal which turns off Metal and switches over to OpenGL.
If you know nothing and comment on it then why bother posting?
if you did not consider my answer at all till now and have not found enough evidence yourself that what i said might be true then why be hostile about it? being ignorant as f*** and all arrogant about it will not bring you any further.
unbelievable some comments some times. also just in case you missed that part, i initiated that topic, so i get notified each time when someone posts. since you did not even have a question and i tried to help you anyway your reply makes even less sense. you could also say thanks, but that does not seem to fit your attitude well.
Thanks for that BH
what is BH?
