On multiple Dell Pro Max 16 Premium MA16250 laptops with Intel i9 and NVIDIA RTX PRO 3000 Blackwell Generation Laptop GPUs, 64GB of RAM we have been having the following issue in Rhino. On my own laptop, this issue got so severe today that I am now in the process of setting up a new laptop.
Essentially, after sometime working in Rhino in any model, doing anything whether it is rotating around in it or modelling, in any display mode, the following Kernel Error will appear:
After clicking “Yes”, Rhino closes, and the computer becomes unresponsive. Other applications that are using the Graphics card, such as Photoshop, Illustrator, etc., then come up with some error like this:
The only way to keep going is to force restart the machine… and then the cycle begins again.
It got so bad today, that just opening Rhino - not even opening a model - would cause this Kernel Crash.
I am sure some of this is some issue in my specific laptop, but the issue exists on many laptops. On other laptops however we have seemingly solved the issue for the most part by doing an uninstall and reinstall of Rhino, the NVIDIA graphics card, and making sure all the drivers are up to date. On my laptop this did not fix it.
Checking the reliability monitor it is always these errors:
Running the laptop with other apps does not trigger this. It is only with Rhino.
We thought at first it may be an issue with the Dell Dock and Dell Monitor connection, and so I was trying first by just connecting to the monitor via an HDMI cable rather than the dock, but that did not remove the issue. I then tried no monitor at all, and just using the laptop, and still the issue appears.
I thought it may be due to the complexity of the meshing in some of my model, so I tried a much simpler model - just some closed brep boxes, but still that causes the issue to occur.
I thought it may be due to displaying meshes from Ladybug GH simulation results, but that did not seem to be the trigger.
Any help would be much appreciated since this is really frustrating.
