Im having an issue where if I print out a layout to image at A1 (840x540) the size of the printed file is nearly 5 times bigger (3504 x 2475.44). This doesn’t happen on pdf files.
Any suggestions. I prefer the quality of the image print out - for some reason the line quality seems better.
When you export to an image, the combination of the paper size (A1) and the resolution will result in an image of a specific size in pixels. When you import that image into some other application, you need to make sure that the resolution is set to the same number to end up with the same “size”.
Said differently, if you need a smaller image but still want to use an A1 sheet, lower the resolution in the print dialog.
