Rhino is reading imported file?
Hi
I had this issue in the past but now Rhino is bombarding me with error messages :slight_smile:
It states: An error occurred while attempting to read the following files: …
I’ve imported an FBX and somehow, Rhino still wants to read this file. How can I cut this connection?
Cheers!
I’d like to know which version of Rhino are you using now? could you run the command SystemInfo in the command line of Rhino and post all popup content here? Thanks.
Thanks for getting back to me!
This is the info:
Rhino 8 SR8 2024-6-18 (Rhino 8, 8.8.24170.13002, Git hash:master @ c3cc7c123163b65d85b517aff795627d5b12166b)
License type: Educational, build 2024-06-18
License details: Cloud Zoo
Apple macOS Version 13.4 (Build 22F66) (Physical RAM: 8GB)
Mac Model Identifier: Mac14,2
Language: en-CH (MacOS default)
.NET 7.0.0
Metal GPU Family Apple 7
Metal GPU Family Common 3
Metal GPU Family Mac 2
Graphics processors
Apple M2
Color LCD (1470 x 956 @ 60.00Hz)
USB devices
None
Bluetooth devices
None
Third party kernel extensions
None
Third party plugins
/usr/lib/usd/libIex.dylib
/usr/lib/usd/libHalf.dylib
/usr/lib/usd/libAlembic.dylib
/usr/lib/usd/libusd_ms.dylib
/usr/lib/usd/libosdCPU.dylib
/usr/lib/usd/libImath.dylib
/usr/lib/usd/libIlmThread.dylib
/usr/lib/usd/libIexMath.dylib
/usr/lib/usd/libtbb.dylib
/usr/lib/usd/libMaterialXCore.dylib
/usr/lib/usd/libMaterialXFormat.dylib
/usr/lib/swift/libswiftNetwork.dylib
/usr/lib/swift/libswiftAppKit.dylib
/usr/lib/swift/libswiftFileProvider.dylib
/usr/lib/swift/libswiftPrivate_BiomePubSub.dylib
/usr/lib/swift/libswiftPrivate_BiomeStreams.dylib
/usr/lib/swift/libswiftExtensionFoundation.dylib
/usr/lib/swift/libswiftCoreML.dylib
/usr/lib/swift/libswiftVision.dylib
/usr/lib/swift/libswiftExtensionKit.dylib
/usr/lib/swift/libswiftWebKit.dylib
/usr/lib/swift/libswiftGLKit.dylib
/usr/lib/swift/libswiftMapKit.dylib
/usr/lib/swift/libswiftModelIO.dylib
/usr/lib/swift/libswiftSceneKit.dylib
/Applications/Rhino 8.app/Contents/Frameworks/RhMaterialEditor.framework “Renderer Development Kit” 8.8.24170.1002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Commands.rhp “Commands” 8.8.24170.13002
/Applications/Rhino 8.app/Contents/PlugIns/NamedSnapshots.rhp “Snapshots” 8.8.24170.1002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RDK_EtoUI.rhp “RDK_EtoUI” 8.8.24170.13002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/MeshCommands.rhp “MeshCommands” 8.8.24170.13002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoRenderCycles.rhp “Rhino Render” 8.8.24170.13002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCycles.rhp “RhinoCycles” 8.8.24170.13002
/Applications/Rhino 8.app/Contents/PlugIns/SectionTools.rhp “SectionTools” 8.8.24170.1002
/Applications/Rhino 8.app/Contents/PlugIns/Displacement.rhp “Displacement” 8.8.24170.1002
/Applications/Rhino 8.app/Contents/PlugIns/PanelingTools.rhp “PanelingTools” 8.8.24170.1002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoDLR_Python.rhp “IronPython” 8.8.24170.13002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/GrasshopperPlugin.rhp “Grasshopper” 8.8.24170.13002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCodePlugin.rhp “RhinoCodePlugin” 8.8.24170.13002
Please download the latest version of Rhino 8 and try it again, https://www.rhino3d.com/download/rhino-for-mac/8/latest/
This error is happening to me. It is frustrating because I can’t even close the popup window - the file list is simply too long and there is no scroll bar, which necessitates a force close.
Hi Nico -
Is this when you import a specific file? If so, can you post or upload that file?
I have submitted it using the crash reporter built-in. It’s not really about the file - I am trying to alert you to the error message which is unclickable, unscrollable, uncloseable, and requires a force quit.
Hi @nicovlogg,
I’ve looked at the .3dm file submitted with your crash report. I’m confused why it contains 1101 1-pixel wide textures. Can we see the original file? Free free to send me a pm.
The file opens here, btw.
– Dale
Hi Nico -
We have that issue on the list as RH-86316 Dialog box that requires force-quit
As Dale says, the original file would be good to have.
I’m not at liberty to share it publicy, is there a submission option?
Hi Nico -
Yes. You can upload files from this page: Rhino Accounts
Make sure to copy a link to this thread in the comments field on the page.
Thanks,
Have done so, thank you.
A fix for this has been made and should appear in SR19.
John
RH-86316 is fixed in Rhino 8 Service Release 19
