Rhino.Inside won't install
I am encountering a complete fail when trying to install Rhino.Inside.
I get a dialog box that says the following:
External Tools - External Tool Failure
Revit cannot run the external application “Rhino.Inside”. Contact the provider for assistance. Information they provided to Revit about their identity: Rhino.Inside®.Revit
System.TypeInitializationException
System.TypeInitializationException: The type initializer for ‘RhinoInside.Revit.AssemblyResolver’ threw an exception.
—> System.ArgumentNullException: Value cannot be null. (Parameter ‘paths’)
at System.ArgumentNullException.Throw(String paramName)
at System.IO.Path.Combine(String[] paths)
at RhinoInside.Revit.AssemblyResolver…cctor()
— End of inner exception stack trace —
at RhinoInside.Revit.AssemblyResolver.set_Enabled(Boolean value)
at RhinoInside.Revit.Core.OnStartup(UIControlledApplication uiCtrlApp)
at RhinoInside.Revit.AddIn.Loader.OnStartup(UIControlledApplication app)
at RhinoInside.Revit.External.UI.ExternalApplication.<>c__DisplayClass10_0.<Autodesk.Revit.UI.IExternalApplication.OnStartup>b__0()
at RhinoInside.Revit.External.ActivationGate.Open[T](Func`1 func, Object state)
at RhinoInside.Revit.External.UI.ExternalApplication.Autodesk.Revit.UI.IExternalApplication.OnStartup(UIControlledApplication app)
at Autodesk.Revit.AddIn.Loader.Autodesk.Revit.UI.ExternalApplication.OnStartup(UIControlledApplication controlledApplication)
at Autodesk.Revit.UI.RevitManagedAppStartupAgency.RevitManagedAppStartup(UIControlledApplication uiControlledApplication, AString assemblyName, AString className, AString exceptionName, AString exceptionMessage)
Can anyone assist here? Thank you!
Hi Robert,
This is most likely plugin conflict, but will need more info to be sure.
What version of Revit, Rhino & Rhino.Inside.Revit are your installing?
Hi Japhy,
Thank you for the response:
RhinoInside.Revit_1.22.8962.17228
Revit
25.2.0.38
20240715_1515(x64)
2025.2
Rhino 7
Rhno 7 Educational btw
Version 7 SR37
(7.37.24107.15001, 2024-04-16)
Educational
Rhino 7 is not compatible with Revit 2025, they changed their .net version to .NetCore8, we were able to get Rhino 8 going (.NetCore 7) but Rhino 7 (.netframework 4.8) is a bridge too far.
Ah - ok. Is that an educational licence issue, or can we upgrade to 8?
Or conversely, is there a compatible version of Revit? (If we can downgrade that).
Educational licenses are fully functional. You can use a 90 day trial or upgrade your Edu license to Rhino 8.
Rhino 7 (and 8) is compatible with Revit 2018-24. There are issue starting to pop up in the older versions of Revit, we recommend Revit 2022+
Got it - my daughter (lic holder) said Rhino doesn’t upgrade. (I dont use it - I’m just finance support :slight_smile: )
Ok - thank you very much for the help and suggested options.
