I just noticed that there is some small bug with Absolute Tolerance
When I have Revit in mm, it opens in Milimiters - correct
but Absolute Tolerance is not right
would be possible to fix it?
Absolute Tolerance comes preset to same value as Revit VertexTolerance in Rhino model units.
Same for Angular Tolerance it uses Revit AngleTolerance value.
Using those values in Rhino should help generating geometry in Rhino and Grasshopper that can be transferred in a more accurate way to Revit.
