I want to change absolute tolerance by RhinoSDK.
Not using dialog.
How can I do?
Hi Clement,
I use C++ Rhino5 SDK.
There is no CRhinoDoc::ModelAbsoluteTolerance().
@Vaker, sorry i thought you are using RhinoCommon. The closest i could find is this example:
I am sure @dale knows a better answer.
c.
Hi Clement,
It works.
Thanks for your help.
This should do the trick:
CRhinoCommand::result CCommandTest::RunCommand(const CRhinoCommandContext& context)
// Copy...
ON_3dmUnitsAndTolerances model_units = context.m_doc.Properties().ModelUnitsAndTolerances();
// Modify...
model_units.m_absolute_tolerance = 0.01;
// Update...
context.m_doc.Properties().SetModelUnitsAndTolerances(model_units);
return CRhinoCommand::success;
– Dale
