I recently tried running RiR, and everytime i start it, it does not respond, then it makes my laptop hangs which i have to force shutdown. I dont know if the laptop is the issue or Rhino or Revit.
Lets start by opening Rhino on its own and running SystemInfo in the command line and posting the result.
Everything looks ok there.
Lets look at a possible conflict with a Revit Addin(s)
A quick check can be done if you get Revit going and see the Rhino.Inside Ribbon.
The other option is to temporally disable addins via this addin.
