All good now, the new version is now available via download:
So, actually, not completly solved… Any ideas on what to do next?
The problem was fixed (temporarlily) but whenever the PC restarts the Rhino.Inside Addin folder under %appdata% gets overridden by an older version:
Hi @arteagaBEGEB,
The new installer do copy files under %ProgramData%\Autodesk\Revit\Addins\%RevitVersion%\
folder only.
Since previous version was under the user profile folder:
- Is it possible that a backup utility has restored the previous version there?
- Or maybe you have your Windows user profile synchronized with a Windows Server station and it restored those files there?
Thnak you a lot
I was having the same issue and this worked for me! Thank you a bunch!
