Rhino.Inside.Revit Version 1.0 Released
The first version of Rhino.Inside.Revit has been released.
Version 1.0 includes no expiration time limit. Feel free to distribute the plugin across your team.
New build types are available. Customize which build will work best for you in the Options dialog:
  1. Stable build - This is the tested build that can deployed to a larger team.
  2. Release Candidate - This is a good build stream to make sure the next release will work for your team.
  3. Daily Build - This is where all the new and prototype components are developed. If you like living on the cutting edge, this is it.
We will continue to add new features to Rhino.Inside.Revit, but do not intend to break anything that exists as the product moves through service release updates.
Please join the conversation with feedback to help us improve Rhino.Inside.Revit.
Hi there, I am new to Rhino Inside Revit and have limited grasshopper experience. I am following along with a bunch of the resources available online and noticing that the “Model Category Picker” is no longer available in the 1.0 release? Almost every video seems to use this parameter. What is a good substitute available in the current release. Thanks
Built-In Category is the new improved version, its searchable.
Thanks for confirming. I was using this yesterday and it seemed to achieve the same goal, but figured I’d ask in case I was missing something. I just got access to Rhino 7 yesterday, so lots to learn with the new Rhino Inside features
