Rhino.Inside.Revit Separate glazing from windows
I am extracting a model from Revit into Rhino. I am looking for a simple solution to separate glazing from windows, so that I can put it on the geometry on separate layers in Rhino.
Sort element parts by material?
Sort by separate categories?
Thank you!
What happens when you bake the elements?
By defaults You will get the layers as per categories and subcategories
