Rhino Inside Revit, Referencing BIM 360 model
How do you use the “Doc” input on some components to reference a BIM360 model. I have used it locally by simply using a .rvt file’s path as the input, in order to reference it from the current file I am working in at the moment. Wondering how I might do the same thing for a BIM360 model that is not hosted locally. I have tried using the sharable link associated with the model, provided by the BIM360 site, but this does not work. They image below describes what I am trying to achieve.
If the file is currently linked this is the suggested way.
Make sure you are on at least 1.4, there was a recent fix in the area.
Thanks for the quick reply.
