Hello all, after updating to the latest pre release build of RIR I am experiencing a peculiar issue with revit 2024. When i open a new blank file in revit, Rhino automatically starts and all rhino plugins starts loading in with out manually clicking on Rhino button on revit tab. I think this is not the way RIR should work. RIR should launch only after manually click on Rhino button inside revit tab. i have already checked the settings too. kindly assist.
@Japhy I can now confirm that, without addins too, Rhino is opening automatically. I doubt that theRevit error is not popping up if i run with out plugins but still in both cases rhino is starting automatically
But if rhino is not starting then how a rhino plugin is starting automatically without opening rhino. Even without plugins it was opening automatically.
I’m assuming they are using RiR as a backend and don’t have a way of keeping it from starting on demand, vs RiR which if the option is check requires the user to initiate.
Hi @asisintel I’m surprised of that behavior. Lands Design can’t load if Rhino doesn’t load first.
@Japhy why do you think it’s Lands Design? Perhaps you are seeing the Lands Design splash window before the Rhino interface, but Rhino loads first, for sure.
If the problem happens without plug-ins, this issue is unrelated to Lands Design.
Thanks @fsalla for confirmation. I even uninstalled Landsdesign and have checked, Rhino still opens automatically. @fsalla does this happen on your end with RIR latest pre-release?
