Hi — I need Rhino.Inside.Revit v1.22 (compatible with Rhino 8.0) for immediate use. Could someone from McNeel or the dev team please share a direct installer link? Thank you!
Sent, do note that we recommend being on the latest Rhino, Revit and Rhino.Inside - Revit versions.
If there is something we can help with please provide additional information.
Hi, I am using Rhino 8.18.25100.11001 with Revit 2024.0.4, build 24.0.4.427.
When I try to use Rhino.Inside.Revit, it says I need Rhino 8.21. I also understand that newer Rhino.Inside.Revit versions may require Revit 2024.3 or later.
Could you please provide an older Rhino.Inside.Revit installer that is compatible with Rhino 8.18 and Revit 2024.0.4?
If possible, I would like to try version v1.23 or any version that can support my current Rhino and Revit setup.
Thank you.
@MUHAMMAD_ARIF_MOHD_R - why not just upgrade Rhino?
I need Rhino.Inside.Revit v1.22 for my Rhino 8. I would be grateful if someone from McNeel or dev team help me out
Sure thing, sent. Do note that build was from over a year ago and does not include the latest fixes, components and optimizations.
