Rhino Import Bug
Has anyone noticed that when you do the normal import of obj and set your settings to whatever it is you want to set it to, everything works okay. However when you go the root of the file path (-Import “C:\file_to_import.obj”), the ImportObjObjectAs option fails, no matter what you set it to, it results to nothing. I set my to ‘ImportObjObjectAs = Layers’ but still, everything imported came into the default layer. I’ve been trying to programmatically set the obj import option in the C# component i am building, however, this keeps failing. Everything else works like the MapYtoZ etc.
@user_9123125
