I think my rhino file is corrupt because when i sub-select a polysurface from a closed solid polysurface and push the geometry to be thin, some of the polysurfaces disappear.
Goal:
Result:
Any solutions to fix this?
Hello - please post a file with the starting object and the thin one - thanks.
Hi Brittney - your objects are in outer space:
Point in world coordinates = 8.02886e+07’4-47/128",2.2518e+07’10-5/32",54’-9"
Move everything closer to the World origin and it should behave better.
That’s the trick, thank you kindly!
