Even moving the cursor into the field “length factor” without adjusting the value could cause Rhino to freeze completely.
May I ask if anyone has encountered similar issue?
Hi -
I haven’t heard of this.
Please post your SystemInfo
result.
Thanks, @wim
As suggested, I’m posting my SystemInfo
below, before I do the stuff which causes Rhino to freeze.
Rhino 7 SR13 2021-12-14 (Rhino 7, 7.13.21348.13001, Git hash:master @ 7696723f74a63695b3c372a89110c0ca8c78b890)
License type: Commercial, build 2021-12-14
License details: Cloud Zoo
Windows 10.0.19044 SR0.0 or greater (Physical RAM: 1.3e+02Gb)
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA Quadro RTX 4000 (NVidia) Memory: 8GB, Driver date: 7-12-2021 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 471.41
- Secondary monitor attached to adapter port #0
- Windows Main Display attached to adapter port #1
OpenGL Settings
Safe mode: Off
Graphics level being used: OpenGL 4.6 (primary GPU's maximum)
Anti-alias mode: 8x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 7-12-2021
Driver Version: 30.0.14.7141
Z-Buffer depth: 24 bits
Total Video Memory: 8 GB
C:\Users\USERNAME\AppData\Roaming\McNeel\Rhinoceros\7.0\Plug-ins\SpeckleRhino2 (8dd5f30b-a13d-4a24-abdc-3e05c8c87143)\SpeckleConnectorRhino.rhp "SpeckleRhino2" 2.1.26.6073
C:\Users\USERNAME\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\EleFront\4.2.2\ElefrontProperties.rhp "ElefrontProperties" 1.0.0.0
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp "Commands" 7.13.21348.13001
C:\Program Files\Rhino 7\Plug-ins\WebBrowser.rhp "WebBrowser"
C:\Program Files\Rhino 7\Plug-ins\rdk.rhp "Renderer Development Kit"
C:\Program Files\Rhino 7\Plug-ins\RhinoScript.rhp "RhinoScript"
C:\Program Files\Rhino 7\Plug-ins\IdleProcessor.rhp "IdleProcessor"
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp "Rhino Render" 7.13.21348.13001
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp "RDK_EtoUI" 7.13.21348.13001
C:\Program Files\Rhino 7\Plug-ins\rdk_ui.rhp "Renderer Development Kit UI"
C:\Program Files\Rhino 7\Plug-ins\import_ACAD.rhp "AutoCAD file import: import_ACAD"
C:\Program Files\Rhino 7\Plug-ins\NamedSnapshots.rhp "Snapshots"
C:\Program Files\Rhino 7\Plug-ins\Alerter.rhp "Alerter"
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp "RhinoCycles" 7.13.21348.13001
C:\Program Files\Rhino 7\Plug-ins\Grasshopper\GrasshopperPlugin.rhp "Grasshopper" 7.13.21348.13001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp "Toolbars" 7.13.21348.13001
C:\Program Files\Rhino 7\Plug-ins\3dxrhino.rhp "3Dconnexion 3D Mouse"
C:\Program Files\Rhino 7\Plug-ins\Displacement.rhp "Displacement"
C:\Users\USERNAME\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\SectionTools\2021.4.30.511\SectionTools.rhp "SectionTools"
Allow me to answer myself.
One work-around could be:
Hi -
What happens when you disable both of these and restart Rhino?
I have the exact same problem… everything freezes when editing annotation options.
And even with elefront disabled the problem persists.
Anyone found a solution?
Thanks
q
