Rhino Evaluation and Commercial side by side?
Hi All,
Is it possible to run Rhino eval and full version side-by-side? I am running Rhino ENG commercial but wanted to do some testing on non-English versions of Rhino - eval. version would be fine. How would I go about this? My eval download defaulted to English…
Thanks,
–jarek
Hi Jarek,
You don’t need to have two licenses/installs of Rhino… Just download the various languages you need via Windows Programs - find Rhino, right-click choose Change and then hit the “Modify” button in the installer panel
Then, when the languages are installed, you can chose them from the Dropdown in Options>Appearance.
I would suggest you create some schemes, one for each language you want - that way you can just open a Rhino in French, German or whatever without disturbing the rest.
https://wiki.mcneel.com/rhino/schemes
Perfect! I will try that. Good suggestion with schemes as well. Thanks Mitch-
–jarek
