Hello
I’ve tried 3 separate times to assign a double sided material with standard Rhino Metal and Paint materials, and crashed every time. After making the double sided material, I right click to apply material and it would crash. However, when I dragged the material directly onto object, it worked fine.
Also crashing when I click the + icon to create a material.
here’s the crash report. First one is for the double sided material, the second is the general material creation. Tried to include the whole crash report in 2 separate posts but each crash report exceeded max character limit so just posting abridged version.
Thanks!
Double sided material crash
Process: Rhinoceros [2441]
Path: /Applications/Rhino 7.app/Contents/MacOS/Rhinoceros
Identifier: com.mcneel.rhinoceros.7
Version: 7.13 (7.13.21320.13002)
Code Type: X86-64 (Native)
Parent Process: ??? [1]
Responsible: Rhinoceros [2441]
User ID: 501
Date/Time: 2021-11-18 11:08:30.993 -0500
OS Version: macOS 11.6 (20G165)
Report Version: 12
Bridge OS Version: 5.5 (18P4759a)
Anonymous UUID: 047D2340-8E68-6F38-C816-423525EA1544
Sleep/Wake UUID: F7FC17DB-F3A4-4ED1-AE00-8D3A1EDB5FAC
Time Awake Since Boot: 9800 seconds
Time Since Wake: 1100 seconds
System Integrity Protection: enabled
Crashed Thread: 0 tid_103 Dispatch queue: com.apple.main-thread
Exception Type: EXC_CRASH (SIGSEGV)
Exception Codes: 0x0000000000000000, 0x0000000000000000
Exception Note: EXC_CORPSE_NOTIFY
Termination Signal: Segmentation fault: 11
Termination Reason: Namespace SIGNAL, Code 0xb
Terminating Process: Rhinoceros [2441]
Application Specific Information:
[ERROR] FATAL UNHANDLED EXCEPTION: System.ObjectDisposedException: Cannot access a disposed object.
Object name: ‘Foundation.NSDictionary’.
at ObjCRuntime.ThrowHelper.ThrowObjectDisposedException (System.Object o) [0x0000c] in <3d8c2e0da31b4784a40c7d9116ca5ede>:0
at ObjCRuntime.NativeObjectExtensions.GetNonNullHandle (ObjCRuntime.INativeObject self, System.String argumentName) [0x00024] in <3d8c2e0da31b4784a40c7d9116ca5ede>:0
at AppKit.NSImageRep.DrawInRect (CoreGraphics.CGRect dstSpacePortionRect, CoreGraphics.CGRect srcSpacePortionRect, AppKit.NSCompositingOperation op, System.nfloat requestedAlpha, System.Boolean respectContextIsFlipped, Foundation.NSDictionary hints) [0x00007] in <3d8c2e0da31b4784a40c7d9116ca5ede>:0
at Eto.Mac.NSImageExtensions.Resize (AppKit.NSImageRep image, CoreGraphics.CGSize newsize, Eto.Drawing.ImageInterpolation interpolation, System.Nullable1[T] imageSize) [0x000b7] in <19c0aec46d40403fa6cd70a23859d6fc>:0 at Eto.Mac.MacConversions.ToNS (Eto.Drawing.Image image, System.Nullable1[T] size) [0x001b2] in <19c0aec46d40403fa6cd70a23859d6fc>:0
at Eto.Mac.Forms.Menu.ButtonMenuItemHandler2[TWidget,TCallback].SetImage () [0x0001e] in <19c0aec46d40403fa6cd70a23859d6fc>:0 at Eto.Mac.Forms.Menu.ButtonMenuItemHandler2[TWidget,TCallback].set_Image (Eto.Drawing.Image value) [0x00007] in <19c0aec46d40403fa6cd70a23859d6fc>:0
at Eto.Forms.ButtonMenuItem.set_Image (Eto.Drawing.Image value) [0x00006] in <67e041f15f0749b68b17153c13181173>:0
at Eto.Forms.ButtonMenuItem…ctor (Eto.Forms.Command command) [0x0000e] in <67e041f15f0749b68b17153c13181173>:0
at Eto.Forms.Command.CreateMenuItem () [0x00000] in <67e041f15f0749b68b17153c13181173>:0
at Eto.Forms.MenuItemCollection.Add (Eto.Forms.Command command, System.Int32 order) [0x00000] in <67e041f15f0749b68b17153c13181173>:0
at RDK.Controls.Thumbnaillist.ThumbnailList.BuildCreateNewMenu (Eto.Forms.ButtonMenuItem submenu_createnew, RDK.DataSources.MenuTaskCollection taskCollection, Rhino.Render.UICommands.UICommandOrigin origin, System.Boolean bOnItem) [0x00082] in :0
at RDK.Controls.Thumbnaillist.ThumbnailList.SetContextMenu () [0x000b9] in :0
at RDK.Controls.Thumbnaillist.ThumbnailList.ControlClick (System.Object sender, RDK.Controls.Thumbnaillist.ControlClickEventArgs e) [0x00021] in :0
at RDK.Controls.Thumbnaillist.ThumbnailViewEx.ControlClick (System.Boolean bOnItem, Eto.Forms.MouseButtons mousebutton) [0x00041] in :0
at RDK.Controls.Thumbnaillist.ThumbnailViewEx.OnMouseUp (Eto.Forms.MouseEventArgs e) [0x00062] in :0
at Eto.Forms.Control+Callback.OnMouseUp (Eto.Forms.Control widget, Eto.Forms.MouseEventArgs e) [0x0000c] in <67e041f15f0749b68b17153c13181173>:0
at Eto.Mac.Forms.MacView`3[TControl,TWidget,TCallback].TriggerMouseUp (Foundation.NSObject obj, System.IntPtr sel, AppKit.NSEvent theEvent) [0x00018] in <19c0aec46d40403fa6cd70a23859d6fc>:0
at Eto.Mac.Forms.MacView.TriggerMouseUp (System.IntPtr sender, System.IntPtr sel, System.IntPtr e) [0x0001d] in <19c0aec46d40403fa6cd70a23859d6fc>:0
at (wrapper native-to-managed) Eto.Mac.Forms.MacView.TriggerMouseUp(intptr,intptr,intptr)
[END ERROR]
[LOADED ASSEMBLIES]
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Versions/Current/Resources/
Xamarin.Mac.dll
monostart.exe
RhinoMac.dll
Mindscape.Raygun4MacRhino.dll
Eto.XamMac2.dll
Eto.dll
Rhino.UI.dll
RhinoCommon.dll
lib/mono/gac/System.Drawing/4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
lib/mono/gac/System.Windows.Forms/4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
RhinoMacBindings.dll
Eto.CodeEditor.dll
ManagedPlugIns/Commands.rhp/Commands.rhp
Yak.Core.dll
ManagedPlugIns/Import_OBJ.rhp/Import_OBJ.rhp
ManagedPlugIns/export_XAML.rhp/export_XAML.rhp
ManagedPlugIns/QuadRemesh.rhp/QuadRemesh.rhp
ManagedPlugIns/Export_OBJ.rhp/Export_OBJ.rhp
ManagedPlugIns/RDK_EtoUI.rhp/RDK_EtoUI.rhp
ManagedPlugIns/export_SVG.rhp/export_SVG.rhp
ManagedPlugIns/MeshCommands.rhp/MeshCommands.rhp
ManagedPlugIns/Export_DAE.rhp/Export_DAE.rhp
ManagedPlugIns/export_PDF.rhp/export_PDF.rhp
ManagedPlugIns/export_IGES.rhp/export_IGES.rhp
ManagedPlugIns/Import_SVG.rhp/Import_SVG.rhp
ManagedPlugIns/BlockEdit.rhp/BlockEdit.rhp
ManagedPlugIns/Export_AMF.rhp/Export_AMF.rhp
ManagedPlugIns/RhinoRenderCycles.rhp/RhinoRenderCycles.rhp
ManagedPlugIns/import_DST.rhp/import_DST.rhp
ManagedPlugIns/export_PLY.rhp/export_PLY.rhp
ManagedPlugIns/Import_AMF.rhp/Import_AMF.rhp
ManagedPlugIns/RhinoCycles.rhp/RhinoCycles.rhp
ManagedPlugIns/RhinoCycles.rhp/RhinoCyclesCore.dll
ManagedPlugIns/RhinoCycles.rhp/csycles.dll
Newtonsoft.Json.Rhino.dll
ZooClient.dll
ValidationClient.dll
Proxy.dll
CloudZooClient.dll
websocket-sharp.dll
crypto.dll
jose-jwt.dll
ManagedPlugIns/RhinoDLR_Python.rhp/RhinoDLR_Python.rhp
ManagedPlugIns/RhinoDLR_Python.rhp/RhinoPythonHost.dll
ManagedPlugIns/RhinoDLR_Python.rhp/Microsoft.Scripting.dll
ManagedPlugIns/RhinoDLR_Python.rhp/Microsoft.Dynamic.dll
ManagedPlugIns/RhinoDLR_Python.rhp/IronPython.dll
ManagedPlugIns/RhinoDLR_Python.rhp/IronPython.Modules.dll
ManagedPlugIns/GrasshopperPlugin.rhp/GrasshopperPlugin.rhp
ManagedPlugIns/GrasshopperPlugin.rhp/Grasshopper.dll
ManagedPlugIns/GrasshopperPlugin.rhp/GH_IO.dll
System.Resources.Extensions.dll
System.Memory.dll
System.Runtime.CompilerServices.Unsafe.dll
Material Creation crash
Process: Rhinoceros [2714]
Responsible: Rhinoceros [2714]
User ID: 501
Date/Time: 2021-11-18 11:36:40.492 -0500
Report Version: 12
Time Awake Since Boot: 11000 seconds
Time Since Wake: 2800 seconds
Terminating Process: Rhinoceros [2714]
at RDK.Controls.Thumbnaillist.ThumbnailList.AddButtonMenu () [0x000c6] in :0
at RDK.Controls.Thumbnaillist.ThumbnailList.AddButtonClick (System.Object sender, System.EventArgs e) [0x00010] in :0
at RDK.Controls.Thumbnaillist.ThumbnailViewEx.CheckOnAddButtonClick (Eto.Forms.MouseEventArgs e) [0x0003f] in :0
at RDK.Controls.Thumbnaillist.ThumbnailViewEx.OnMouseDown (Eto.Forms.MouseEventArgs e) [0x00079] in :0
at Eto.Forms.Control+Callback.OnMouseDown (Eto.Forms.Control widget, Eto.Forms.MouseEventArgs e) [0x0000c] in <67e041f15f0749b68b17153c13181173>:0
at Eto.Mac.Forms.MacView`3[TControl,TWidget,TCallback].TriggerMouseDown (Foundation.NSObject obj, System.IntPtr sel, AppKit.NSEvent theEvent) [0x00053] in <19c0aec46d40403fa6cd70a23859d6fc>:0
at Eto.Mac.Forms.MacView.TriggerMouseDown (System.IntPtr sender, System.IntPtr sel, System.IntPtr e) [0x0001d] in <19c0aec46d40403fa6cd70a23859d6fc>:0
at (wrapper native-to-managed) Eto.Mac.Forms.MacView.TriggerMouseDown(intptr,intptr,intptr)
[END ERROR]
[LOADED ASSEMBLIES]
Xamarin.Mac.dll
monostart.exe
RhinoMac.dll
Eto.XamMac2.dll
Eto.dll
Rhino.UI.dll
RhinoCommon.dll
Eto.CodeEditor.dll
Yak.Core.dll
ZooClient.dll
Proxy.dll
CloudZooClient.dll
websocket-sharp.dll
crypto.dll
jose-jwt.dll
System.Memory.dll
