did the code here change to inject data as inputs. when running this demo no matter what value you adjust in the code it just runs the default in the gh script. also those inputs no longer have GH_IN: group tags, has that changed?
Hey @cerver,
I am having a similar problem that most of the example scripts from this repository do not work. My script (MyCube.gh) however works.
It would be great to have a tutorial on what inputs (other than number slider) and outputs (other than a mesh) are possible and how to do it.
Laurin
i found the issue to that code, I will see if I can do a PR , its a simple fix
