Rhino.Compute latest nightly.link returns 404 not found
@AndyPayne - Hi Andy, I am following your guide for installing on an Azure VM but the “module_compute.ps1” is unable to fetch the latest build zip archive as nightly.link is returning a 404 not found.
===>  Download and unzip latest build of compute from https://nightly.link/mcneel/compute.rhino3d/actions/artifacts/661907533.zip
Exception calling "DownloadFile" with "2" argument(s): "The remote server returned an error: (404) Not Found."
I have searched around manually but cannot find the latest build anywhere. Is the build artefact missing ? Is there a workaround to obtain the zip?
'- - - EDIT - - -
I have pulled the code from github and built and deployed it as a workaround but I’ll keep this post in case you were unaware that your script if failing at the moment.
regards
dan
Thanks for the heads up. Looks like the artifact expired (>90 days). I’ll kick off a new build with the same source to freshen it up!
Update: done :+1:
Hi @will - we are encountering the same issue, rhino compute artifact for 7 is expired..
I’ve bumped the old v7 build again. Should be working now.
hey @will , we are getting the same issue again.
I just kicked off a new build for v7 so it should be working again. Sorry for the inconvenience.
