Hello everyone,
I’m currently working on a project using Rhino.Compute. I’ve successfully cloned the repository, configured the appsettings.json file, and started the server without any issues. The console shows that the server is running on http://localhost:6500.
However, when I try to send a simple GET request to http://localhost:6500/version using Postman, I consistently receive a 500 Internal Server Error. I’ve already:
Verified that the server is running properly (dotnet run shows no errors during startup);
Checked the firewall and network settings;
Confirmed that Rhino is installed and activated;
Attempted requests to other endpoints like /health, but the issue persists.
Here’s the output from the terminal after sending the request:
(Insert any error logs from the terminal here)
Does anyone know what could be causing this issue or how I can debug it further? Any guidance would be greatly appreciated!
Thank you in advance,
Rênicles Oliveira
