A friend of mine made a surface using the ‘curve network’ command. However when she switched the view from wireframe to rendered it doesn’t show up, only some parts can be seen, around 5% of the total surface area.
Her model has no straight lines and has an organic shape.
Does anyone have any idea? If you have any please reply as soon as possible. Thank you for taking the time to read this.
Hi Danny - usually this type of shading defect can be fixed by retrimming the surface. In this case, select the surface and Invert Hide - this will isolate the surface - I guess you need to turn off any locked layers as well for now. Start UntrimAll with nothing pre-selected and select the surface- use the same curves to split or trim the surface again and it should look OK.
It looks to me like the trims from the objects on the layers ‘Interior w 1’ and ‘useful area’ are the ones causing the trouble, I’ll see if I can reproduce it here.
