Thank you for the work + willingness to let us test
theoutside
(Kyle Houchens)
November 10, 2026, 5:38pm
102
sign me up as a tester .. this is wonderful
Insane ! … what a person can do with Ai assist these days. It’s a force multiplier, especially on well defined topics like programming.
That looks awesome! Would love to test it!
simon7
(Simon)
November 14, 2026, 10:43pm
105
Thanks for the update! I’d be very interested in trying it out. Looking forward to receiving the download link. Much appreciated!
simon7
(Simon)
November 16, 2026, 12:25am
106
What surprised me most is how easy and intuitive the plugin is to use. More importantly, the rendering results are truly amazing, and the rendering speed is remarkably fast
That looks great Simon! I’m glad you’re finding it easy to use and fast to render.
altamiro.aj
(Altamiro A J)
November 16, 2026, 11:34am
108
Can I get a link too please, I have some models I would like to test it out
michaelkreft:
Marker Sketch
@michaelkreft you might want to start your own topic for this plugin…
Yes of course. Sorry I was not attempting to hijack this thread! I have created a separate post here:
Hi all,
I’ve been building a plug-in that draws your Rhino model as a marker sketch, the kind you’d do by hand for a design presentation. It runs live in the viewport as a display mode and can save to flat or layered files.
(Lamp model is a mesh)
[1-desk-lamp]
How it works:
Give each part a material: plastic, metal, glass, wood, gems. There are 76 to pick from. Or create your own.
Orbit to the view you want. The sketch draws in a second or two.
Save a PNG.
Save as a layered PSD (not inclu…
Claude designed this case for a camera pcb I’m working on via RhinoMCP. Rendered in the custom engine I am building, which claude setup the materials and lighting for.
This is the results after the first prompt. From my experiments I think claude handles primitives pretty well but fails when it comes to organic surfaces. Still the results are pretty good, it picked up the cutouts for the usb port, sd card, battery, buttons, screen and lens. It did not attempt to create screws.
Baris
November 26, 2026, 4:03pm
112
Finally, I had time to try it and it worked very well, so that I decided to make it a plug in:
Hi all,
I think everybody who worked with point clouds in Rhino/GH noticed that it may be difficult with bigger clouds. Since I often work with point clouds and larger ones made working almost impossible, I searched a way to deal with them and created a plug-in with the help of Claus. I called it Megabat since their echolocation may remind of a laser scanning process.
The main advantage is the Preview:
Large clouds and meshes are displayed through a level-of-detail octree or a thinned proxy, …
scottd
(Scott Davidson)
November 26, 2026, 4:25pm
113
An idea for organics forms could be sketches added to the prompts. That has worked for me sometimes
Part of the problem is a good way to describe organic shapes thru sketchs or words
altamiro.aj
(Altamiro A J)
November 27, 2026, 1:18pm
114
“A problem well stated is a problem half solved.”
― Charles Franklin Kettering
