Rhino AI testing
I hate doing layouts and annotations by hand. Now Rhino AI does it in a decent time and if something is not the way I want, I just tell it to adapt…
Martin would you be so kind as to describe your workflow? What model are you using to do these drawings and how are you prompting it?
Also this makes me wonder, can AI control Grasshopper sliders and bake many different variations?
I asked for a simple plan I can use as a router template with some dimensions….
Rhino AI can do all kind of grasshopper acrobatics. Two of my favourites so far are replace components and align to make things more readable
I’ve been building a render engine plugin for Rhino with claude.
My main aim is to render juice with a layer of melt water from ice cubes on the top.
To do this I used something called agentic visual regression, apparently.
Generate Code → Compile → Render Image → Compare with Target Image → Feed Error Back to AI → Repeat
It’s no commercial renderer but it does do a bespoke task I’m not sure is straight forward in any other render engines, although I’d love to know another way to do it.
I told claude to use voxels in it’s SSS calculations with a 3d gradient applied to them. The voxels then drive how SSS’y and transparent the juice is. I’m impressed with the results so far.
Speaking as someone who spent his first 3 or 4 years after graduation cutting his teeth pumping out hundreds of engineering drawings, mostly for machine shops and fabricators, I lament that engineering drawings also seem to be something of a dying art
This was a problem even before AI was on the scene. Some took an attitude that with 3D models and model based definitions, 2D drawings were old fashioned. I disagree very strongly to this day. Drawings are more than just dimensions and instructions for the machinist. They serve as contracts between customer and supplier. They’re invaluable aids for on-site workers who just want to print out something, rather than open a laptop to check a model every time they have a question. They exist to ease communication and explain what the purpose of a component is, and how to relates to an assembly. A good drawing is also indispensable when it comes to part and assembly traceability
I wrote a post about how it would be a boost to Rhino if they implemented GD&T features for layouts, and was pleased to see this was a feature that made the cut for Rhino 9
Suffice to say, I think it’s a shame that in all likeliness, from here on out, engineering drawings will fall out of common use. AI will only accelerate this. In the small startup where I work now, I am the only engineer that seems to care about them. I’m fairly sure the guys younger than me have never even made one. Much to my frustration, I have been proven right again and again about drawings serving as vital documents for traceability. Being old fashioned about things and keeping digital as well as hard copies of my drawings has eliminated tons of guesswork when it comes to revisiting projects from 3+ months ago. By contrast, colleagues of mine that forgo this step seem to constantly be misplacing their CAD models that contain the information I need (part numbers etc)
Much to my frustration, we’ve even had subcontracted parts come back from machining that are incorrect, as the detail on the model we supplied was insufficient. All they needed was a drawing with the note M8x1.25 detailed
I think PMI is the next step on this, but sadly Rhino still doesn’t support STEP 242 PMI export/import. It would be lovelly to have PMI support for rhino.
Essentially, you make the detailing on the 3d model itself and it can have saved views so when the final users opens the file it has everything on it, some software even suport the creation of “2d drawings” automatically based on the saved views and data, and generate the PDFs from it.
I get your point.
In my work the deliverables are 3D geometries and in rare situations 2D *.dxf
Plans are only used for verification. And in most situations no one ever looks at a plan. So it is an additional effort which under normal circumstances no one ever uses.
The good part about PMI is having it done in 3d and easily printable in 2d.
Here’s a few more images from the render engine I’m building with claude. The planning of the light path in the optics bench test was first coded python and then claude built the entire setup in Rhino.
The second render engine I’m working on is Marker Sketch. Designed to create a hand drawn marker sketch from nurbs or meshes. The different pen layers can be saved as PSD for later editing.
Router model is from grabcad.
That is absolutely sick @michaelkreft
Thank you very much! If there is enough interest in this beta I could be looking for testers
From that render I can almost smell the PrismaColor Markers from back in the day. That is awesome!
Haha fake marker sketch…. Looks cool!
I’d love to be a part of this!
This looks great allready.
What a time to be alive!
Please add me to the list
Would love to try out and give some feedback Mike… :smiley:
Thanks for the interest! I will be in touch with those of you who have responded this weekend with a download link. Currently it’s running on Windows and Rhino 8.
