Has anyone investigated AI integration for design development and documentation in an architecture setting? Free form modeling and concept image generation are helpful to a degree, but it would be much more valuable if we could leverage it in later phases to cut down production times without it messing up the design. For instance, if I draw a wall section with the entire material assembly and is a dimensioned plan can it spit out accurate model?
Yes, Its easy to imagine a year from now much of these processes will be automated. The LLM’s know a lot but given proper context (details) the output is only going to get better.
I just tried these tools out for the first time and was surprised by the accuracy of the modeling based using industry standard language given the early state of the tool and integration with Rhino.
Yeah, and I think there is a lot we can do with prompts and inputs. Can you send us an example of a good drawing? I would tend to show AI what i consider a good drawing is, perhaps in ahte form of a Rhino model. Then see how it would apply that to another building i had to see how well it would create the new drawing.
The input also might include a clipping plane of the area that I wanted the section to take place in the new building.
I likely will have time to share something by tomorrow, but my schedule is filled the rest of my day. With that said, Claude is capable of “brute forcing” seeing in the program via screenshots (it did this without prompting it). I fed it a simple structure that I had a 2D CAD plan & section as well as a model reference and it was able to spit out a properly modelled 3D version in our firm layer system in about 1-2minutes.
I am not sure about the token spend, but it hasn’t tripped a session limit on the basic plan.
Another thing to consider here is tooling. Using the right tools are going to greatly increase productivity.
This is an example of a plugin created by Guillermo from the AiPanel for adding and manipulating kitchen cabinet configurations. This same process can be done with anything, as well a being part of a prompted workflow.
how “simple” were the spaces in section? like each room a rectangular prism or were the spaces more complicated?
The model circled in blue was entirely modelled by the examples provided and the new plan and section with little to no notation beyond my description. It is pretty limited scope; however, it is not a typical construction and material method. I found no mistakes and was able to adjust the design in the model without ruining the model.
@Neal_Barber I would be very much interested in the process the other way round!
Meaning: creating prope production/shopdrawings from a model.
Did you try it that way as welll?
Are there example drawings we would consider good enough? I expect this is not to hard in that I would give the model, come clipping planes and and example of a drawing or two and see how far it would get.
It had no issue interpolating a model from the unlabeled section and plan sketches included in the screenshot. It was also about to make modifications / edit the model properly.
I expect that it will have issues with more challenging conditions such as corner and non- orthogonal polysurface joints.
We are able to get automatically updating construction drawings directly from our models without issue in Rhino 9 with Clipping Sections & Drawings at this point without AI assistance.
The next thing that I plan to investigate is how effective AI will be to help notate, dimension, label and populate schedules for production drawings. I suspect this will be a task that AI can perform well and help close the gap to BIM software on these aspects.
I was playing with schedules here. I expect a schedule template would have even been better.
And then started to work on placing BIM information through the Rhino model that could be harvested later.
@Neal_Barber, would you mind sharing your results here?
This may or may not be helpful. My work with setting up a Claude MCP has been very productive. Claude helped me set up the connection. My interface is completely through the Claude desktop.
I was able to give Claude a 3d model design I had made previously, ask it to review and improve the design. It produced a new model which was an improvement, gave me requested 2d drawings, provided a parts list in Excel with quantities, costs and vendors (which it located on its own), build a grasshopper computational design with sliders for important variables, and update the parts list ,cost data and any 2d outputs immediately whenever a new variation was baked. And output nested 2d drawings of parts that were to be cut on a CNC router. My original design took me about 3 months of trial and error. If I had used Claude then, I would estimate maybe 3 days of iterations before I had a better design.
forgive my ignorance, but what is the project for, it looks like a jaulosie window opening? did claude give you the 2D drawing with colors too? this stuff looks quite impressive
Of the drawings or further investigations in AI project documentation?
This thread: Clipping Sections - Layer Control with Linked Blocks - Rhino / Rhino for Windows - McNeel Forum
Shows how we are getting drawings from models.
Sorry. The original design was for an active stage background. The verticle slats are able to rotate 360 degrees, powered by low speed, high torque motors connected to the slats by a series of timing belts and pulleys. The motors are controlled wirelessly by the auditorium’s lighting and sound panel. What I show in the above design information is what Claude provided, not the original design.
The 2d drawing is just as Claude provided. My only input was to tweek some of the colors to give more contrast btw parts.
