Rhino 9 request: dropdown menu with old values in gumball
would be nice the following as shown in the pic:
Bie
Please no.
Hi @bie
I and other users have asked for similar items to be added to the gumball like in your request.
I requested this but can’t remember the thread I think it would be a great time saver along with your wish it would be in last used. The menu I drew was for illustration only I would like a pie menu which has been shown to be working (in another thread) but never adapted into Rhino.
RM
Previously requested in several topics, such like these two:
I am very Interested in why for you this suggestion world not be beneficial
Me too. Especially how it would affect your way of doing things if it was a configurable feature.
I think it clutters the gumball and I prefer snapping. I’m also wondering how often identical values are really needed? The next request could then be a calculator inside gumball…
But ok, if it is an option which can be deactivated I don’t mind
After looking at the linked topics, it becomes clear this input stack would be needed in every command which requires a numerical input and not just in a gumball text field.
The idea is to be able to either:
  1. Click on a tiny floating icon that appears next to the mouse pointer to expand a list with the recently used numbers;
  2. Click inside an auto-expanding list with the recently used nunbers next to mouse pointer.
Personally I prefer approach #2, because it reduces the mouse clicks to the bare minimum.
I would also suggest, when inputting any large value, to be able to type:
1k (or simply k) for 1000
5h for 500
this might be helpful in architecture when you draw in mm.
Also, this would help people without a numpad keyboard .
You can already enter values in whatever unit you want, not sure if km works for kilometers…
Rhino’s UI expert can make a good job in making this feature uncluttering.
In architecture modeling, imagine in a facade design task, where you are moving blocks in various positions, on Y and X axes: sometimes it is nice to have more than the last used input.
to be able to deactivate it also sounds good!
Hahaha!
This would be very nice.
A lot of times even when it’s the same distance move, I have to type either +2 or -2 depending on the orientation of the surface. I always felt it’s such a small annoying thing.
Are you aware that +/- can be flipped by pressing shift?
Sure, and I do sometimes.
what I was asking is different:
• if I type 1k I want to move by 1000, and is not me specifying the units → of course rhino will use the template units: move by 1000 mm if I my template is in millimeters, or feet if template is in feet…)
1k is just a shortcut for 1000
1h for 100
1m for 1000000 (but here I realize the conflict that my request would bring, as 1m would mean 1 meter…)
I did mean to ask if there’s something I was missing. Thank you very much. I did not know about Shift key to flip +/-
But I still think the request would be quite beneficial. Oftentimes a few different dimensions get repeated.
Does this not work with rotate? or there’s something else I’m missing?
± works just fine with shift key when drawing lines ore moving objects, but it doesn’t seem like shite key works for rotating
@l11 it was recently implemented in the wip version so far, i don’t think it will be coming to v8.
