Rhino 9 Beta UI defaults to Italian and cannot be changed to English
Hi McNeel Team,
I recently installed Rhino 9 WIP, but the user interface opened in Italian by default and I am unable to change it to English.
Steps attempted so far:
Tried running the SetLanguage command, but the command is not recognized.
Edited settings-Scheme__Default.xml to replace it-IT with en-US under DefaultTemplateFile, but the UI remains in Italian after restarting.
Checked Rhino Options (Opzioni), but could not locate any Language/Localization settings.
System Info:
Rhino 9 WIP (9.0.26251.12303, 08/09/2026)
OS: Windows 10/11
Educational License
Could you please advise on how to install or force the English UI package in Rhino 9 WIP?
Thanks,
Michele
You meant BETA?
Language setting should be here:
Thanks, but that’s not where the problem is — I’m already on that page.
Screenshot 1 is Options > Appearance on my machine: “Language used for display” is there, and it’s set to Italiano (Italia). The trouble is that the dialog itself doesn’t respond correctly. As soon as I click in the right-hand pane — on the dropdown or on the checkboxes — the panel jumps to a different page: I end up on Grid (screenshot 2) or Location (screenshot 3) instead of staying on Appearance.
You can see that something is off in the way the dialog is drawn, too: the blue selection bar from the tree on the left runs across the full width of the window and covers the controls on the right. In screenshot 1 it hides part of “Completa automaticamente comandi” and “Usa completamento automatico voci simili”; in screenshot 2 it covers the first radio button under “Apply grid changes to”.
So the clicks don’t land where the controls appear to be, and I can never actually open the language dropdown and choose English — the UI stays Italian.
This is Rhino 9 BETA on Windows. Is this a known hit-testing / DPI-scaling issue with the Options dialog? And is there a way to set the display language outside the dialog — a command, or an .ini/registry setting — so I can get out of Italian in the meantime?
Some extra details on my setup, since this looks DPI-related.
I’m on a laptop with an external monitor attached:
  • Laptop display: 1920 Ă— 1080, scaling 175%
  • External display: 2560 Ă— 1080, scaling 175%
I keep both at 175% because anything lower makes the icons too small to work with comfortably, so this isn’t a setting I can simply leave at 100%.
Given that Windows applies DPI per monitor, I suspect the Options dialog isn’t handling the scaling correctly: the selection bar from the left-hand tree is drawn across the full width of the window, over the controls on the right, and the clicks clearly don’t land where the controls are painted — clicking in the right-hand pane takes me to a different page (Grid, Location) instead of staying on Appearance.
I’ll test with both displays set to 100% and with the external monitor disconnected, and report back whether the dialog behaves correctly in those conditions. But at 175%, which is my normal working setup, the Options dialog is effectively unusable — and since that’s the only place to change the display language, I’m stuck with the Italian UI.
Is there a way to set the display language outside the Options dialog — a command, or a settings/registry entry — as a workaround in the meantime?
Rhino 9 SR0 2026-9-8 (Rhino 9 BETA, 9.0.26251.12303,
License type: Educational, build 2026-09-08
License details: Cloud Zoo
Expires on: 2026-10-23
Windows 11 (10.0.26200 SR0.0) or greater (Physical RAM: 64GB)
.NET 10.0.12
Hybrid graphics configuration using DirectX
Primary display: NVIDIA Quadro P3200 (NVidia) Memory: 6GB, Driver date: 3-7-2025 (M-D-Y).
Integrated accelerated graphics device with 4 adapter port(s)
  • Laptop’s primary display device
Secondary graphics devices.
Intel(R) UHD Graphics P630 (Intel) Memory: 1GB, Driver date: 3-6-2025 (M-D-Y).
Integrated graphics device with 3 adapter port(s)
  • Windows Main Display is laptop’s integrated screen or built-in port
  • Secondary monitor attached to adapter port #1
DirectX Settings
Safe mode: Off
OpenBLAS: OpenBLAS 0.3.30 DYNAMIC_ARCH NO_AFFINITY Haswell MAX_THREADS=64.
C:\Users\miche\AppData\Roaming\McNeel\Rhinoceros\packages\9.0\Karamba3D\3.1.60519\net8.0-windows\Karamba3D_LicensePlugin_Rhino8.rhp “Karamba3DLicense”
C:\Program Files\Rhino 9 WIP\Plug-ins\Commands.rhp “Commands” 9.0.26251.12303
C:\Program Files\Rhino 9 WIP\Plug-ins\rdk.rhp “Renderer Development Kit”
C:\Program Files\Rhino 9 WIP\Plug-ins\3dxRhino.9.rhp “3DxRhino.9”
C:\Program Files\Rhino 9 WIP\Plug-ins\UpdatesAndStatistics\UpdatesAndStatistics.rhp “UpdatesAndStatistics” 9.0.26251.12303
C:\Program Files\Rhino 9 WIP\Plug-ins\RhinoRenderCycles.rhp “Rendering di Rhino” 9.0.26251.12303
C:\Program Files\Rhino 9 WIP\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 9.0.26251.12303
C:\Program Files\Rhino 9 WIP\Plug-ins\NamedSnapshots.rhp “Snapshots”
C:\Program Files\Rhino 9 WIP\Plug-ins\MeshCommands.rhp “MeshCommands” 9.0.26251.12303
C:\Program Files\Rhino 9 WIP\Plug-ins\RhinoCycles.rhp “RhinoCycles” 9.0.26251.12303
C:\Program Files\Rhino 9 WIP\Plug-ins\Grasshopper\GrasshopperPlugin.rhp “Grasshopper” 9.0.26251.12303
C:\Program Files\Rhino 9 WIP\Plug-ins\Displacement.rhp “Displacement”
C:\Program Files\Rhino 9 WIP\Plug-ins\SectionTools.rhp “SectionTools”
I changed the WIP in the topic title to Beta
I have a similar issue. I can change the language on the options, but the preference is not preserved during application restart, so it never takes effect. Im using Rhino Beta for MAC (9.0.26251.12304, 08/09/26)
