I have a program in Russian, how can I change the language to English?
In the equivalent of Options> Appearance (in Russian) there should be a dropdown at the top with language choices - it looks like this in an English interface:
If you have English in there, choose it, close Rhino and re-open. Rhino should no be in English.
If English is not in the list, you will need to download the language pack. Go to Windows Programs, find Rhino V7 in the list right click on it and choose “Change…” A dialog will come up , choose the “Modify” button, then add the language(s) you want and click the “Install Now” button. Then go through the procedure above.
Thank you!
ср, 3 нояб. 2021 г. в 11:21, Helvetosaur via McNeel Forum <mcneel@discoursemail.com>:
