Rhino 9 Beta - Grasshopper 1 Menu/Title Bar Colors Not Using Rhino Colors
Hi McNeelies,
I just noticed that the Grasshopper 1 menus and inactive title bar colors in Rhino 9 Beta do not appear to use Rhino color key/values. Which they do in previous Rhino versions, I think (left: Rhino 8, right: Rhino 9):
I might also just not have configured my Rhino 9 advanced keys correctly. If so, maybe you can point me to the relevant ones?
Cheers and best,
Andes
Bump, maybe @Gijs or @AndyPayne might know (i.e. the great UI overhaul + still developing for GH1).
Hi @AndersDeleuran,
I’ve logged a ticket - thanks.
– Dale
Hi @AndersDeleuran,
This is what I get on my computer on Rhino 8.
I guess your Windows has same grey color for active and inactive caption.
But as you see in the video if the user has the active color set to green like here the caption color change when the Grasshopper window loses the focus.
To support Rhino dark mode in Grasshopper now Grasshopper window uses same colors Rhino uses instead of global Windows colors for the caption.
Your video is not showing the Rhino caption but this is Rhino caption inactive.
And this is active.
As you see Rhino changes its caption color when is not active also.
I’m afraid I don’t quite follow. Are you referring to these (accent) colour settings?
Edit: The accent settings seems to be involved indeed:
Edit II: Maybe this demonstrates the window title bar issue better:
And of course the Rhino 9 GH menu colors do not look like the ones in Rhino either.
Now I see thanks!
This will be fixed on next release.
RH-99635 is fixed in Rhino 9 Service Release 2 Release Candidate
The title bar issue is now fixed :clap:, but the menu colors are still not using Rhino key/values:
@AndersDeleuran Is it possible you’ve got some setting that’s been modified in your setup (note the white canvas background)? I just ran the latest stock Rhino 9 build and then tested the menus against the title bar, etc and the results all matched exactly.
I just tried deleting all my Grasshopper customisations (i.e. the xml files in AppData\Roaming\Grasshopper) and that does not appear to be the issue:
I’m using custom color schemes in Rhino, which I’m guessing might be related:
I’m not sure if there is a command for exporting all the advanced Rhino options key/values? But have modified some additional colors in there in there as well. Might be relevant.
