Rhino 8 Worksession Section Styles
Hello everyone,
The section style is a new feature of Rhino 8 making it perfect comparing with the previous versions, but I am dealing with a complex architectural project, so I seperated all my files to get together by using worksession of Rhino. Despite the fact that I have already adjusted the section style for all layers in each different worksession attachments, as I create a section in main worksession file, it behaves there is no section style. In short, there is nothing inhereted from each different files about section style to show the hatches as I had adjusted. What is the solution of that case?
Thanks for the report.
Can you please post a simple example that we can test with?
I have been running into the same issue where I am trying to work session several architectural models together to assemble a quick drawing set. However the section styles are either being lost or are not being referenced correctly across the inactive files.
@wim can you please help investigate this issue?
We need your help to see the problem at our end. Please share a model, the version of Rhino 8 you are using and steps to recreate the issue. We appreciate your time and help.
Hello everyone,
I wanted to ask if there has been any update on fixing this issue? Unfortunately, I seem to be encountering similar problems on my end, and it’s becoming quite a challenge. Any insights or solutions would be greatly appreciated, Thanks
Can you please share a model that shows the issue, with steps to recreate? Thanks.
