brian
(Brian Gillespie)
September 29, 2023, 12:21am
121
Rhino 8 BETA (8.0.23271) is now available for Windows and Mac
Bugs Fixed:
Grasshopper: Fix all annotation components so that they do not automatically generate objects with null inputs. (RH-77349 )
Print: Layouts panel "Print" button scrambles print ui (RH-77361 )
Properties:
Layer dropdown drawing too big of a color swatch (RH-77355 )
Properties > Layer drop down too large (RH-77351 )
SDK: RhinoCommon: RhinoObject.UserData doesn't seem to save to the object when saving the file (RH-48844 )
UI Cleanup: Sidebars are too difficult to resize (RH-77150 )
Mac-Only Changes
Bugs Fixed:
CommandHistory: CommandHistory doesn't scroll to the bottom (RH-73417 )
Options: Mouse: Mouse manipulation grayed out (RH-77211 )
brian
(Brian Gillespie)
October 3, 2023, 10:44pm
122
Rhino 8 BETA (8.0.23276) is now available for Windows and Mac
Bugs Fixed:
ComputeVertexColor command doesn't appear to work? (RH-77165 )
Display: Curves and hatches coplanar to a clipping plane are not visible on a "Parallel Reflected" viewport (RH-77341 )
Print: Closing print dialog with Image File selected and reopening shows incorrect controls (RH-77364 )
Rendering: Post Effect: Issues with clipping planes (RH-77305 )
UserText: Retain key when value is removed (RH-77459 )
Tasks Completed:
Templates: Perspective viewport uses Shaded display mode by default (RH-70700 )
Mac-Only Changes
Bugs Fixed:
Options: Restore Alt key shortcuts (RH-77352 )
brian
(Brian Gillespie)
October 5, 2023, 11:08pm
123
Rhino 8 Beta (8.0.23278) is now available for Windows and Mac
Bugs Fixed:
Groundplane: ground plane line shows with shadows only enabled (RH-77504 )
Rendering: Rendering through Frame buffer increases memory usage (RH-77045 )
Selection: Selection issue in specific scene (RH-77476 )
Crashes Fixed:
ViewCaptureToClipboard: ViewcaptureToClipboard fails at 3x the resolution (RH-77482 )
Regressions Fixed:
dan
(Dan)
October 10, 2023, 10:42pm
124
Rhino 8 Beta (8.0.23283) is now available for Windows and Mac
Bugs Fixed:
Display: Imported fbx material transparency (RH-77484 )
Localization: Typo in German Physical Material (RH-77548 )
Rendering: Textures: Deleting grouped textures does not work (RH-77535 )
Toolbar: MRU repeats custom buttons (RH-77516 )
Features Added:
Installer: Removed Visual Studio 2010 Redistributable BUT NOT MicroScribe Digitizer support (RH-75663 )
Regressions Fixed:
BooleanDifference: Boolean Difference slow in V7 & V8, fast in V6 (RH-66281 )
Mac-Only Changes
Bugs Fixed:
Options: Aliases cleared (RH-77610 )
Preferences: Removed Right mouse button settings from Rhino application settings (RH-77507 )
Zoom: In perspective view zoom crossing window is not zooming in. (RH-77547 )
Windows-Only Changes
Regressions Fixed:
BlockManager: BlockManager command missing from Rhino 8 (RH-77609 )
dan
(Dan)
October 12, 2023, 10:48pm
125
Rhino 8 Beta (8.0.23285) is now available for Windows and Mac
Bugs Fixed:
Curve: Curve can't be Piped nor Sweeped (RH-38483 )
Grasshopper: Query Model Layers - Filter with square brackets (RH-77545 )
Rendering: Spotlight not working (RH-75736 )
Crashes Fixed:
Print: Command: Eto.Forms.PropertyBindingException: Could not set property 'MultipleLayouts' on 'Rhino.UI.Forms.ViewModels.PrintOptionsViewModel' (RH-77564 )
Mac-Only Changes
Bugs Fixed:
Keyboard Shortcuts: Added shortcut support for Alt + Home, End, A to Z and 0 to 9 (RH-77352 )
Options:
Settings > Keyboard: cannot type macros (RH-77555 )
StatusBar: Layer popup does not scale on Mac (RH-77634 )
Bugs Fixed:
Menu: Window > Panels > Constraints (RH-77624 )
Options: Ctrl+Function (F1, F2, F3, etc) keys do not run the commands assigned to them (RH-77553 )
dan
(Dan)
October 13, 2023, 1:02pm
126
Rhino 8 Beta (8.0.23286) is now available for Windows and Mac
Bugs Fixed:
Display: Grid On/Off setting is broken for details and layouts (RH-77703 )
Print: Vector Print: Rhino hangs when switching between layouts (RH-77627 )
Mac-Only Changes
Bugs Fixed:
Rendering crashes trying to open Render Window (RH-77706 )
Bugs Fixed:
Toolbar: Drafting toolbar does not refresh (RH-76827 )
UI Appearance: Command line can be undocked, but will disappear after closing and reopening Rhino (RH-77549 )
will
(Will Pearson)
October 17, 2023, 10:36pm
127
Rhino 8 Beta (8.0.23290) is now available for Windows and Mac
Bugs Fixed:
Annotation: Hatch: Hatches with dots as elements - dots don't display (RH-77733 )
File IO: ExportWithOrigin: Meshes ignores origin (RH-77777 )
MeshFromLines: MeshFromLines, Mesh.CreateFromLines bug in V8 (RH-77495 )
ScriptEditor: None in python list in Grasshopper is being output as string "None" (RH-77705 )
Mac-Only Changes
Bugs Fixed:
Grasshopper: Grasshopper drawing glitches (macOS Sonoma regression) (RH-76455 )
will
(Will Pearson)
October 19, 2023, 10:52pm
128
Rhino 8 Beta (8.0.23292) is now available for Windows and Mac
Bugs Fixed:
UI Appearance: RUI icons get deleted (RH-74605 )
brian
(Brian Gillespie)
October 25, 2023, 12:23am
129
Rhino 8 Beta (8.0.23297) is now available for Windows and Mac
Bugs Fixed:
Options: Options > Keyboard colors (RH-77792 )
Selection: Somewhat hard to select a curve with a linetype (RH-72212 )
WindowLayout: Rhw file removes UI (RH-77795 )
brian
(Brian Gillespie)
October 31, 2023, 10:11pm
130
Rhino 8 Beta is now closed.
To try Rhino 8, please download the Rhino 8 Evaluation .
