brian
(Brian Gillespie)
June 13, 2023, 11:38pm
101
Rhino 8 WIP (8.0.23164) is now available for Windows and Mac
Bugs Fixed:
Annotation: Hatch: Hatch > Match doesn't work well with gradient hatches (RH-75292 )
BoxEdit: BoxEdit panel causes a delay in History updates (RH-71250 )
Display: Rendered mode camera misses some objects (RH-75117 )
Display Metal: Moving a ClippingPlane or ClippingSection has artifacts and is missing fill (RH-74787 )
Inset: Input disappears (RH-75079 )
RelocateGumball: Relocating the Gumball with Ctrl/Cmd has been broken (RH-74452 )
Rendering: Materials: Material editor name issues (RH-75197 )
SDK: RhinoCommon: CreateCustomMeshMapping does not set projection (RH-75305 )
SelBoundary: Allow preselection (RH-74455 )
Split: Split point and point filters (RH-75179 )
UVEditor: Unwrap focus problem for select seams step (RH-74514 )
Unwrap: ability to restore previous seam selection (RH-68857 )
WindowLayout: Special-case Command Line when restoring Window Layouts rhw files on Mac (and vice versa) (RH-74623 )
Crashes Fixed:
ExtractClippingSections: Crashes (RH-75304 )
Enhancements:
DupFaceBorder: DupFaceBorder on merged SubD faces (RH-75246 )
Features Added:
Properties: implement new section properties (RH-74428 )
UVEditor: UV Editor: allow constraining edge chains to curves (RH-72578 )
SDK Enhancement:
SDK: RhinoCommon: Expose full ON_Extrusion::CreateFrom3dCurve (RH-75208 )
UI Change:
Choose One Object: "Show object type details" is renamed to "Show curve type details" (RH-75181 )
Mac-Only Changes
Bugs Fixed:
Display Metal:
Clipping plane looks pixelated where overlapping with cap (RH-74061 )
UsesRoughnessTexture Crash in Technical display mode (RH-75224 )
Windows-Only Changes
Bugs Fixed:
EditScript: RhinoScript Editor - syntax tree empty (RH-75229 )
brian
(Brian Gillespie)
June 20, 2023, 11:32pm
102
Rhino 8 WIP (8.0.23171) is now available for Windows and Mac
Bugs Fixed:
Layer panel doesn't apply custom section style if no hatch is selected (RH-75315 )
Annotation: Linetype: Number of segments (RH-74303 )
ArcBlend: report colinear input (RH-75337 )
FilletSrf: FilletSrf preview black on Metal (RH-73590 )
Keyboard: Tab missing on the key list (RH-69990 )
MeshBooleanDifference: MeshBooleanDifference missing option to keep input (RH-73753 )
NamedCPlane: No restore after rename (RH-70300 )
Options: Display modes: cannot change the shadow intensity (RH-75209 )
Osnap:Point: OSnap - One Shot "Point" snap doesnt get set when clicked. (RH-75320 )
Panels: LayerStateManager does not get checked (RH-74584 )
Section Tools: Sections: remove underscores from command line options (RH-74885 )
Toolbar:
Mac-Only Changes
Bugs Fixed:
Commands: Apple Silicon: Dimension commands can't be repeated (RH-72758 )
Display Metal: GH Custom Previews don't draw in Rendered, Arctic (RH-74981 )
Print: Empty preview image (RH-70709 )
Toolbar:
Dim command run from toolbar button does not repeat on Mac (RH-73072 )
Button background color stays in blue after being clicked on Mac (RH-72028 )
Bugs Fixed:
Dark Mode: Block edit dark mode version (RH-72929 )
Eto: Dropdown in GridView doesn't select if mouse down is not over an existing grid row (RH-68190 )
Help: Rhino 8 does not load offline-help in Help panel (RH-75271 )
Enhancements:
Help: Made offline help for all users instead of current user only (RH-75379 )
brian
(Brian Gillespie)
July 5, 2023, 4:19pm
103
Rhino 8 WIP (8.0.23185) is now available for Windows and Mac
Bugs Fixed:
Annotation: Linetype: Thickness wrong on layout (RH-74805 )
Arctic display: Object fails in Arctic mode (Metal) (RH-73824 )
ClippingPlane: Section styles: by parent (RH-68813 )
Display: Section of clipping plane gets wrong color (RH-74356 )
Display Metal: Arctic mode loses details (RH-74077 )
File IO: SVG Import creates too many materials (RH-75451 )
Localization: error (pt): Localization Team: String formats do not match (RH-75394 )
MeshOutline: MeshOutline jumble (RH-51636 )
OSnap:From: From Osnap with curve constraint (RH-75518 )
PushPull:
Extend option doesnāt seem to work on the roof (RH-74300 )
PushPull on a surface should make a solid (RH-74992 )
Radius: Constrained if a curve is selected with other objects (RH-75517 )
Rendering: Cycles: Decal doesn't render (RH-75381 )
Rendering: Materials: Per face materials are lost when exploding and rejoining (RH-58191 )
SDK: RhinoCommon:
RhinoDoc.ReadFile interrupted with Ć¢ā¬Ėimport scaling - DimensionNumbersĆ¢ā¬ā¢ (RH-67948 )
RhinoObject.UserData doesnāt seem to save to the object when saving the file (RH-48844 )
SubD: Bug in ON_SubD::InterpolateSurfacePoints() (RH-75471 )
Toolbar: update NewInV8 (RH-70381 )
UVEditor: Doesn't keep up with material assignment (RH-75216 )
Cosmetics:
SphereTangentToThreeSurfaces: Trim=Yes flips surface normal (RH-47938 )
Enhancements:
CopyToClipboard: Sub-object can be copied and pasted as a new object (RH-54501 )
Drag and Drop: Support importing toolbar container definition files (*.rhc) (RH-75339 )
Gumball: Double-click a gumball control to enter relocate mode (RH-75362 )
MeshBooleanDifference: Added Tolerance=Auto/Document/Zero options to mesh boolean commands (RH-75600 )
PushPull: PushPul: Added Toggle option to switch between Extrude and Extend mode (RH-73362 )
RhinoCode: Allow debugging of imported code (RH-71462 )
Undo: Keeps sub-object selection (RH-59423 )
Features Added:
Display: Move all Technical pipeline features and capabilities into the pipeline base class (RH-57451 )
SDK: RhinoCommon: SelLast does not catch the last created geometry in GhPython (RH-54558 )
Regressions Fixed:
Annotation: Hatch: Hatch fails in V8 (RH-70992 )
Mesh: Render mesh degradation in WIP8 (RH-74129 )
SDK Enhancement:
Tasks Completed:
Rendering: Cycles: Update C wrapper around Cycles (RH-67470 )
UI Change:
ClippingPlane: New ClippingPlaneProperties command (RH-75355 )
Usability Problems Fixed:
ZoomSelected: Include clipping plane widgets (RH-75519 )
Mac-Only Changes
Bugs Fixed:
Annotation: Text: Text is not editable from floating Properties panel (RH-75366 )
Display Metal: Switching Maximized Viewports locks up (RH-75433 )
Grasshopper: Recent Items > List has formatting issues (RH-72701 )
Layer: Column state not remembered between sessions (RH-75410 )
Menu: Remove "View > Show Toolbar" (RH-75438 )
Panels: Lose focus on Mac (RH-75555 )
Rendering: Cycles: CyclesX: With factory-default settings, Cycles is set to CPU (rather than Metal) (RH-75426 )
Cosmetics:
Eto: UI: Eto-provided Cancel and "OK" buttons are missing top borders (RH-74496 )
PropertiesPage: Properties: Text: Height field is too short (RH-67275 )
Bugs Fixed:
ChangeLayer: Allow keyboard input (RH-72268 )
LineTypeDisplay: Dots displays as continuous (RH-73035 )
UI Appearance: Resizing dialog of Emap, Zebra, Curvature Analysis etc. is difficult (RH-72813 )
brian
(Brian Gillespie)
July 11, 2023, 11:37pm
104
Rhino 8 WIP (8.0.23192) is now available for Windows and Mac
Bugs Fixed:
Annotation: Custom dimension style name missing from dropdown (RH-73677 )
Annotation: Hatch: Import Hatch Pattern drawing too dark in dark mode (RH-75657 )
Annotation: Linetype: No scaling in details (RH-71045 )
FilletSrfToRail: FilletSrfToRail selection tuneup (RH-75631 )
Rendering: Cycles: Mesh artifacts on Ground Plane with Optix (RH-61315 )
Rendering: Materials: Nested blocks that have by parent shows different material in viewport than in raytraced (RH-74500 )
SynchronizeRenderColors: Use layer color's opacity value (RH-75666 )
UDT: CageEdit preview incorrect for degree 1 objects (RH-75623 )
UI Appearance: Cascade tooltip not yet ported to v8 (RH-74889 )
Undo: Materials added by block insert won't undo (RH-75559 )
Crashes Fixed:
Rendering: Cycles Viewport: Instant crash (RH-67125 )
Features Added:
MeshIntersect: Command cannot be cancelled (RH-49273 )
Regressions Fixed:
Annotation: Hatch: Model space hatch scale doesn't stick (RH-75640 )
DocumentProperties: Changes to display precision do not stick (RH-74242 )
MeshBooleanDifference: Failure case (RH-73555 )
SDK Enhancement:
SDK: RhinoCommon:
Added Rhino.HostUtils.DescribeGeometry() (RH-75398 )
Support exporting IGES format (RH-52082 )
Mac-Only Changes
Bugs Fixed:
Display Metal:
Dotted linetypes not displaying correctly (RH-75610 )
Array command crashes Rhino when using large dimensionsā¦ (RH-75100 )
Print: Preview upside down (RH-75380 )
Performance Improvements:
Rendering: Render Performance on Apple M1 (RH-61623 )
Bugs Fixed:
Annotation: Text: Command line steals focus (RH-75619 )
brian
(Brian Gillespie)
July 12, 2023, 5:32pm
105
Rhino 8 WIP (8.0.23193) is now available for Windows and Mac
Bugs Fixed:
File IO: Failed to Save File - read only (RH-75731 )
Enhancements:
Rendering: Default sample count of Raytraced viewport is changed to 100 (RH-73847 )
Regressions Fixed:
brian
(Brian Gillespie)
July 19, 2023, 12:19am
106
Rhino 8 WIP (8.0.23199) is now available for Windows and Mac
Bugs Fixed:
ClippingPlane: Block instance sections (RH-75675 )
CurvePiping: Curve piping isn't working fully with new linetype styles (RH-72822 )
Display:
Grid appears and hops around between block instances (RH-75755 )
Array commands do not preview blocks in ghosted display mode (RH-75720 )
Layer: Collapse layer crash (RH-75863 )
MeshBooleanDifference: MeshBooleanDifference samples (RH-69152 )
MeshSplit: MeshSplit failure (RH-54541 )
Toolbar:
Recently Used toolbar duplicates used buttons (RH-73272 )
UI Appearance: Menu pops up under auto-hide sidebar (RH-73310 )
Enhancements:
ReducePointCloud: Added "Percent" option for points to remove (RH-75754 )
Features Added:
Section Style: Include boundary linetype option (RH-75676 )
Mac-Only Changes
Bugs Fixed:
Display Metal: Gumball disappears in certain display modes on Mac (RH-75690 )
Layer: Changing properties deselects layers (RH-68930 )
Cosmetics:
Dark Mode: Toolbars: Floating containers borders look weird in Dark Mode (RH-75729 )
UI Change:
Toolbar: Popup toolbar from middle mouse button works more like Windows version (RH-73445 )
Bugs Fixed:
Installer: Smart App Control on Windows 11 blocks Rhino installation (RH-74165 )
Layer: Drag-and-drop layers to the bottom is not possible (RH-72466 )
Toolbar: Tools Toolbar layout gets partly invisible (RH-72216 )
UI Appearance:
Rhino looses focus when dragging out a toolbar (RH-73898 )
Icon Scaling refresh (RH-71928 )
WindowLayout: Workspaces: Keep size of containers between sessions (RH-70275 )
Enhancements:
Eto: Layers: Scroll the list on drag and drop (RH-73413 )
brian
(Brian Gillespie)
July 25, 2023, 11:57pm
107
Rhino 8 WIP (8.0.23206) is now available for Windows and Mac
Bugs Fixed:
ClippingPlane:
Clipping fills are missing on block items (RH-75859 )
Missing Clipping Fills or Edges on nested blocks (RH-72039 )
Display:
Display modeās section fill issue (RH-75935 )
Section fill incorrectly displays color for shaded selected clipping plane (RH-75929 )
Dynamic Clipping Section (RH-75238 )
Disabling option Use section styles (RH-75722 )
FilletSrf: FilletSrf Tangent and Bulge Sliders range are editable (RH-73759 )
ScriptEditor: Script editor splash screen tune up (RH-75622 )
ShowEdges: Edge Analysis mode should ignore display mode edge settings (RH-76000 )
UI Appearance: Floating containers cannot be sized to be a single row high (RH-71817 )
Enhancements:
File IO: Export to SVG should use the ETO UI (RH-75934 )
Regressions Fixed:
WireCut: WireCut KeepAll=yes is ignored in V7 and V8. Okay in V6. (RH-68897 )
UI Change:
Toolbar: Hide Ć¢āĀ§ on empty buttons (RH-73071 )
Mac-Only Changes
Bugs Fixed:
line types and widths are not showing in lates v8 wip for mac. (RH-75923 )
Display Metal: ClippingPlane shows a white plane (RH-75903 )
Options: Mouse > MMB > custom toolbar (RH-72343 )
Panels: Show Panels menu highlight remains highlighted when scrolling (RH-75908 )
Bugs Fixed:
File IO: Print all layouts to image (RH-75932 )
FileExplorer: Reverts to medium sized icons (RH-75891 )
Keyboard Shortcuts: Zoom Window through shortcut Ctrl+W after restoring a named view sends a W to the command line instead (RH-73347 )
will
(Will Pearson)
August 1, 2023, 11:55pm
108
Rhino 8 WIP (8.0.23213) is now available for Windows and Mac
Bugs Fixed:
ClippingPlane: Custom depth cannot be set to zero on clipping plane creation (RH-75926 )
Display: Slow Grasshopper preview (RH-76037 )
File IO: SVG: Failure case (RH-76062 )
Gumball: gumball extrude and cut handles remain visible in orthogonal view (RH-75845 )
LayerStateManager: LAYERSTATES aren't functioning after upgraded to Rhino 8 from Rhino 7 (RH-76102 )
Libraries: Running _Libraries command to show Libraries panel causes doc to be in an Edited State (RH-75938 )
Properties: Add Accept Default to -Properties (RH-76138 )
ScriptEditor:
SelBadObjects: Bad objects can't edit or delete (RH-76081 )
Toolbar: PopUpToolbar: layer container tune up (RH-75937 )
Cosmetics:
Tabs: Dragging tab label needs padding-right and rounded look (RH-73341 )
ScriptEditor: Script Editor - consolidate errors (RH-75737 )
Mac-Only Changes
Bugs Fixed:
Commands: File Explorer command does nothing (RH-75916 )
ScriptEditor: Fails to start on Mac (RH-76023 )
Bugs Fixed:
Display: View manipulation hits sticky points (RH-74121 )
Options: Mouse: Alignment of UI elements (RH-76002 )
Rendering: Materials: Materials panel: Focus shifts in material search (RH-76053 )
Enhancements:
Print: Use Eto Print Dialog on Windows (RH-75732 )
brian
(Brian Gillespie)
August 8, 2023, 10:34pm
109
Rhino 8 WIP (8.0.23220) is now available for Windows and Mac
Bugs Fixed:
ArcBlend: Doesn't trim correctly (RH-75955 )
ClippingPlane: Clipping does not update dynamically when set to "Include Selected" (RH-75855 )
Display Metal: Object Intersection Not Visible in Technical Display (RH-76113 )
Gumball: Incorrectly shows scale handles after relocating (RH-75851 )
Layer: Old Layers panel SDK functions need updating (RH-68678 )
MouseOver Highlight: SubObject selection / Mouseover highlight does not work for (poly)surface vertices (RH-75852 )
OpenNURBS: ON_Plane::IsValid should check for NaN (RH-76196 )
PersistentOnSrf: PersistentOnā¦ object snaps do not work with Copy (RH-76080 )
Print: Technical and pen mode (RH-11615 )
Rendering: Cycles: Rectangular lights not visible in reflections (RH-76178 )
Reset: Running Reset command causes doc to be in an Edited State (RH-75939 )
UI Appearance: Resize areas should have consistent width (RH-74337 )
Enhancements:
Rendering: Materials: Thumbnails now render only discrete sizes of 64, 128, 256, 512 and any in-between sizes get scaled during display (RH-76114 )
Features Added:
Grasshopper: Added "Point Cloud Contour" component (RH-75858 )
SDK Enhancement:
SDK: Cannot explode text, leaders, and dimensions from RhinoCommon (RH-50235 )
Mac-Only Changes
Bugs Fixed:
UI problems with macOS Sonoma (RH-75678 )
Features Added:
File IO: Backup current 3dm file before saving over it (RH-68397 )
UI Change:
Viewports: Added the down-arrow button to viewport tiles for opening the viewport menu (RH-70593 )
Bugs Fixed:
Annotation: Hatch: Gradient Hatch not properly scaled when placed inside a block (RH-76003 )
brian
(Brian Gillespie)
August 15, 2023, 10:45pm
110
Rhino 8 WIP (8.0.23227) is now available for Windows and Mac
Bugs Fixed:
Annotation: Text: Text Selection Not Working In Perspective Projection Detail with Layout Scaling Enabled (RH-75634 )
CPlane: AutoAlign: Gumball does not undo correctly with autocplane (RH-75832 )
File IO: Order of layouts in PDF (RH-75933 )
Panels: Isolate makes the Filter panel appear (RH-72881 )
Rendering: Materials: Single color texture fails on physically based (RH-74876 )
SDK: SDK installer should not check for VS 2019 (RH-76312 )
SelLayer: Should work by selecting an object (RH-76252 )
Selection: Surface gets selected when hidden isocurve is hit (RH-75787 )
Snap: Remove snapping to invisible objects (RH-76109 )
UVEditor: UV Editor: Re-unwrap must use symmetry tip from Unwrap (RH-74636 )
Enhancements:
Gumball: Shift key can activate 2D scaling on plane handle after dragging has started (RH-75535 )
History: Supports snapping to SubD vertices (RH-76098 )
Print: Add UI to the print dialog to allow for saving layouts as individual PDFs (RH-76192 )
Features Added:
Grasshopper: Grasshopper does not naively support lightweight extrusions (RH-42662 )
Regressions Fixed:
Display: Top-most object in nested blocks do not show wires (RH-76298 )
Layer: Layers panel - Copied layer location incorrect (RH-76262 )
Rendering: Materials: Single color texture using object color not working properly when object is colored (RH-74877 )
SDK Enhancement:
SDK: RhinoCommon: Mesh.CreateFromCurveExtrusion flawed (RH-68211 )
Story:
Tasks Completed:
Rendering: Cycles: Fold RhinoRenderCycles project into RhinoCycles (RH-67468 )
Mac-Only Changes
Bugs Fixed:
ImportPreferences: Allow ImportPreferences (Settings) to accept .plist files for backward compatibility (RH-76260 )
Options: Display Modes: Clipping plane settings (RH-75612 )
Preferences: Import/Export Preferences commands need renaming and aliases on Mac (RH-76259 )
Rendering: Materials: Investigate the work needed to support the use of the alternative texcoord-set in Procedurals (RH-75067 )
Bugs Fixed:
Rendering: Textures: rendered mode bitmap images adjustment makes object transparent (RH-76282 )
brian
(Brian Gillespie)
August 22, 2023, 9:59pm
111
Rhino 8 WIP (8.0.23234) is now available for Windows and Mac
Bugs Fixed:
CPlane: AutoAlign: AutoCPlane: Make it work in a detail (RH-75563 )
Docking: make the target zones larger (RH-72559 )
Fin: Too much fin (RH-76377 )
Layer: Sticky column width and order (RH-69711 )
Move: Moving dimensions differs depending on pre or post selection (RH-75643 )
NamedView: Named view icons are gone (RH-76442 )
Print: Vector PDF from Technical (RH-76212 )
Rendering: Materials: materials: cannot assign default, by default (RH-76397 )
SelectionFilter: Selection filter switches off (RH-76342 )
WindowLayout: Window layouts: incorrect layout restored (RH-72000 )
Crashes Fixed:
Trim: Hard crash running Trim (RH-76341 )
Enhancements:
Print command - prefill filename for Rhino PDF (RH-76354 )
SDK Enhancement:
SDK: RhinoCommon: PointCloud.RemoveRange slow (RH-76488 )
Containers: Toolbars: Single docked toolbar does not refresh (RH-70356 )
Rendering: Textures: Texture control slider range (RH-76362 )
Mac-Only Changes
Bugs Fixed:
CommandPrompt:
Undocked command prompt on mac has focus issues (RH-73672 )
The command control appears after restarting Rhino when Use command options dialog option is on (RH-75176 )
Menu: Window > Panels > Command History entry missing (RH-75915 )
Rendering: Cycles: Rendering on Mac: blank image (RH-73275 )
Bugs Fixed:
Grasshopper: Bake: bake component is broken (RH-76347 )
brian
(Brian Gillespie)
August 29, 2023, 10:50pm
112
Rhino 8 WIP (8.0.23241) is now available for Windows and Mac
Bugs Fixed:
Block: Properties panel, Block Instance tab issue (RH-76574 )
ClearAllMeshes: Doesn't clear technical meshes (RH-76579 )
Display: Section curve color (RH-76424 )
ExtractClippingSlices: Uses block on a layout (RH-75231 )
File IO: Read and Write file formats with options (RH-70646 )
Grasshopper: Grasshopper preview of dimension doesn't show correct text gap when compared to actual Rhino drawing code (RH-76173 )
PackageManager: Rhino tries to load plug-in twice after updating package (RH-70611 )
Print: Vector print crash (RH-76580 )
Rendering: Cycles Viewport: Focal blur fails (RH-76044 )
Rendering: Realtime SDK: Rendering: Cycles: Hidden objects in block instances are rendered (RH-76516 )
Rendering: Textures: Missing image files dialog issue (RH-76441 )
Section Tools: Use deleted geometry (RH-76273 )
SubD: ON_SubDVertex::SetControlNetPoint(*,true) needs to clear the cache of 2 rings of faces. (RH-76334 )
UDT:
UI Appearance: Rhino hides when hovering over unpinned settings menu (RH-73342 )
Cosmetics:
Rendering: Materials: Layer material swatch only shows diffuse color and disregards texture map (RH-51792 )
Rendering: Texture Mapping: Empty name lists as (unnamed) (RH-67395 )
Crashes Fixed:
Display Metal: com.mcneel.rhinoceros.RhCore:MetalSemaphore::Wait(long long) (RH-76230 )
ScriptEditor: Improve Python 3 language server performance (RH-76225 )
Mac-Only Changes
Bugs Fixed:
Display: Metal: Selected mesh sub-faces won't shade-highlight (RH-72301 )
Sweep2: refit tolerance limited (RH-76552 )
Bugs Fixed:
Annotation: Linetype: Line weights are only showing center line (RH-76547 )
Dark Mode: Point Cloud Contour (RH-76193 )
Display: Reconsider adding back pixel alignment for orthogonal lines (RH-76211 )
Grasshopper: Components:
Extrude is broken (RH-76348 )
Extrude non planar curves not working (RH-76350 )
Extruding a curve in GH results in a solid (RH-76349 )
Panels:
unpinned container overlaps dialogs (RH-76202 )
All Rhino Panels should support F1 Help (RH-76339 )
Regressions Fixed:
Display: Single backface color (RH-76617 )
brian
(Brian Gillespie)
September 5, 2023, 11:18pm
113
Rhino 8 WIP (8.0.23248) is now available for Windows and Mac
Bugs Fixed:
Display: Shade-highlight highlights wrong objects (RH-76687 )
FilletCorners: FilletCorners converts polycurve linear segments to degree 2 curves (RH-76759 )
Grasshopper: Extrude curve failure (RH-76758 )
Gumball:
Gumball keeps drawing dynamic circle after mouse is released (RH-76731 )
Cutting creates duplicate of objects that are close to the extrusions (RH-75853 )
Layer: Layer's Match properties doesn't match section style (RH-76735 )
MeshSplit: Moose mesh split failure (RH-67023 )
Rendering: Cycles:
Cycles: Ground plane with bump map has mapping issues (RH-37825 )
Environment altitude incorrectly used in Raytraced (RH-62381 )
Decal issues (RH-75658 )
Artifacts with Clipping Plane (RH-62567 )
Section Tools:
Clipping drawing update: unhighlight (RH-76819 )
Report text tune up (RH-76701 )
ClippingSections: depth tune up (RH-76605 )
SmartTrack: Add a way to draw a line past a smarttrack point with defined distance (RH-76152 )
SplitRefitSurface: Fails when not preselected (RH-76681 )
Crashes Fixed:
Tooltip form crashes on popup toolbar. (RH-76714 )
Rendering: Cycles Viewport: Crash in raytraced mode moving control points (RH-76419 )
Enhancements:
SplitRefitSurface: Added "ShowGrips" option to RefitTrim and SplitRefitSurface commands (RH-76685 )
Regressions Fixed:
TextObject: Group option overrides thickness (RH-76740 )
UI Change:
LayerStateManager: No option to restore Section Style or New Detail On properties (RH-76742 )
Mac-Only Changes
Bugs Fixed:
Display Metal: Backface color settings don't work in Metal/Macā¦ (RH-76628 )
Rendering: Blue and Red channels are mixed up (RH-76784 )
Bugs Fixed:
Code Editor Control: New Grasshopper C# Script Editor locks up entire system (RH-75785 )
Layer: Delete and Undo of layers changes does not work when mouse is in Layer Panel (RH-73690 )
ScriptEditor: System.Windows.Forms is missing (RH-76726 )
brian
(Brian Gillespie)
September 8, 2023, 6:47pm
114
Rhino 8 WIP (8.0.23251) is now available for Windows and Mac
Bugs Fixed:
ClippingPlane: Include Selected - support curves (RH-76791 )
Layer: Layers drag to sort (RH-76878 )
Mesh: Mesh settings behave in an unexpected way (RH-76874 )
MeshSphere: MeshSphere > Quad version is not symmetrical (RH-76881 )
Print:
PDF export contains annotations off canvas (RH-76577 )
Raster print from Technical view (RH-76697 )
Use Hidden Linetype for Fake2d Output (RH-76402 )
PushPull: PushPull face does not extend (RH-76849 )
Rendering: Cycles: Groundplane: Cycles doesn't show objects if camera is below the ground plane (RH-60443 )
Rhino Inside: Rhino Render (ccycles.dll) fails to load in Rhino Inside Revit (RH-56927 )
SDK: RhinoCommon: Add missing documentation to SubDFace.SurfaceCenterFrame and SubDFace.ControlNetCenterFrame (RH-76639 )
Section Tools:
UI Appearance: Dark Mode annotation tabs (RH-76423 )
Crashes Fixed:
Regressions Fixed:
Layer: Expand/Collapse context menu items should work with sublayers (RH-76916 )
Make2D: Multiple ClippingPlanes (RH-76226 )
UI Change:
Gumball: Ctrl+Double-click a handle relocates Gumball with numeric input (RH-76815 )
Mac-Only Changes
Bugs Fixed:
Grasshopper: Convert from Extrusion to Brep (RH-76738 )
UI Change:
Keyboard: Use Command+2 to 6 for changing viewport display modes (RH-69988 )
Bugs Fixed:
UI Appearance: scrollable dialog content gets lost (RH-74086 )
v
brian
(Brian Gillespie)
September 12, 2023, 9:55pm
115
Rhino 8 BETA (8.0.23255) is now available for Windows and Mac
Known Issues:
We had to update our code signing certificates this week, so youāll likely get some warnings from Windows about Rhino not being recognized. We think itās safe to install anyway.
Bugs Fixed:
Code Editor Control: C# Code suggestions to show return values (RH-76821 )
Display: Tab for box mode on a SubD is busted in shaded modes (RH-76873 )
DraftAngleAnalysis: DraftAngleAnalysis - make the moving SubD show draft angle when control points are dragged (RH-76925 )
FilletEdge: Filletedge - can't select any edges (RH-76901 )
Gumball: Scale handle remains visible after scaling a curve to 0 (RH-76993 )
LineTypeDisplay: Linetype segments don't match linetypes in V7. (RH-72906 )
Print: Need each printers list of sheets (RH-76683 )
Properties: Object Properties Change Layer Mac issue (RH-76970 )
Enhancements:
Modeling Aids: Add a way to draw a line past a smarttrack point with defined distance (RH-76152 )
Features Added:
Section Tools: ExportClippingSectionInfo command saves .csv on Windows and .txt on Mac (RH-76954 )
Mac-Only Changes
Bugs Fixed:
ScriptEditor: On start, window goes behind Rhino window (RH-76876 )
brian
(Brian Gillespie)
September 20, 2023, 12:24am
118
Rhino 8 BETA (8.0.23262) is now available for Windows and Mac
Bugs Fixed:
Block: Linked Block Parent Layer Does Not Lock Block (RH-59294 )
ChangeSpace: ChangeSpace Result does not preserve original orientation (RH-77126 )
Display:
Intersection curves not correct in Technical display with Clipping plane (RH-76932 )
Snap point display (RH-77060 )
Grasshopper:
Bounding box of block instance issue (RH-77101 )
Extrude issue far from origin (RH-77048 )
Grasshopper: Bake: Baked content doesn't update after changing attributes (RH-76989 )
Grasshopper: Components: Scale override does not work (RH-76988 )
Rendering: Rendering through Frame buffer increases memory usage (RH-77045 )
Toolbar:
Crashes Fixed:
Make2D: Make2D via a python script crashes WIP (RH-72621 )
WindowLayout: Restore layout crash (RH-76986 )
Regressions Fixed:
Properties: Scriptable _-Properties _Object missing IsoCurve options (RH-69191 )
Mac-Only Changes
Bugs Fixed:
Display Metal: Transparent mirrored block instances (RH-77021 )
Section Style: By Clipping Plane does not work on Mac (RH-76867 )
Crashes Fixed:
Code Editor Control: Crash with legacy Grasshopper C# and VB components (RH-77024 )
brian
(Brian Gillespie)
September 21, 2023, 7:32pm
119
Rhino 8 BETA (8.0.23264) is now available for Windows and Mac
Bugs Fixed:
Layer: Panels: State of layers in floating Layer panel is not the same as docked panel (RH-77184 )
LocationSettings: Change of Location doesn't stick (RH-77069 )
Rendering: Cycles Viewport: Raytraced pixels are shifting in viewport and in view capture (RH-77157 )
Toolbar: Display dark mode icons need improvement (RH-76990 )
Mac-Only Changes
Bugs Fixed:
UI Appearance: Mac inactive tabs are too difficult to read (RH-77171 )
Crash fixed when switching or closing viewports
brian
(Brian Gillespie)
September 27, 2023, 2:15am
120
Rhino 8 BETA (8.0.23269) is now available for Windows and Mac
Bugs Fixed:
Rhino Render Advanced Settings section keeps opening (RH-77302 )
Code Editor Control: Show current parameter description text below the method text in method signature help (RH-77140 )
Display:
Layout Layer Color has no effect on detail border colors (RH-72385 )
Consistently display snap point on a clipping plane (RH-77059 )
OSnap: Right click OSnap doesn't set focus back to command line (RH-77246 )
Print:
Dialog: View and Output Scale: Window Set is being remembered. (RH-76945 )
Rhino PDF allows printing with layout size instead of single paper size (RH-77235 )
Rendering: Realtime SDK: Rendering: Cycles: Doesn't support clipping planes that are not visible (RH-77185 )
Crashes Fixed:
Display: Crash in DrawShadedMeshes when SpaceMouse attached (RH-76119 )
ScriptEditor: Crashes when searching (RH-77264 )
Regressions Fixed:
SDK: RhinoCommon: CustomRenderMeshProvider returns null for ThickeningId, "On" (RH-77191 )
Bugs Fixed:
WindowLayout: The Command Prompt visibility checkbox is missing in V8 (RH-73624 )
