ShynnSup
(Shynn Sup)
March 27, 2024, 7:37pm
1
Hi, I don’t get why texture mapping does not display my values instead it read “Varies” what is that supposed to mean???
Where is the match dimensions of object button that used to create a bounding box around the object and display those dimensions in Rhino 7?
pascal
(Pascal Golay)
March 27, 2024, 8:16pm
2
Hello- it would say Varies if more than one obiect is selected and the numbers are not the same on each… is that what you have?
ShynnSup
(Shynn Sup)
March 27, 2024, 8:34pm
3
Hi Pascal, that must be it, it was a grouped object. Can’t I have a big bounding box for the entire selection?
pascal
(Pascal Golay)
March 27, 2024, 8:59pm
4
Hello- you can apply the same mapping to all at once - like BoxMapping that will give all the selected objects the same box - is that what you mean? You can type in that Varies field as well to set all objects’ X,Y or Z.
