Hi everyone,
I’m having an issue with the built-in PDF Export plug-in in Rhino 8 after updating to the latest service release.
Rhino Version
- Rhino 8 SR33 (8.33.26188.13001)
- Windows 11
- .NET 8.0.15
Problem
Whenever I try to print using Rhino PDF, I receive:
Failed to load PDF Export plug-in
If I open PluginManager and manually try to load the PDF Export plug-in, I get:
Plug-in Export_PDF.rhp cannot be loaded: ID is already in use
What I’ve already tried
Verified the PDF Export plug-in is enabled.
Attempted to manually load the plug-in.
Ran a Rhino Repair installation.
Restarted Windows.
Confirmed the plug-in file exists at:
C:\Program Files\Rhino 8\Plug-ins\Export_PDF.rhp -
Searched my system and found only one
Export_PDF.rhp(there is also anExport_PDF.pdb, but no second.rhp).
Additional observation
In my SystemInfo, the PDF Export plug-in does not appear under “Rhino plugins that ship with Rhino”, even though the Export_PDF.rhp file exists in the Rhino Plug-ins folder.
The only third-party Rhino plug-in installed is ClimateStudio for Rhino 8.
Has anyone seen this with SR33, or is there a way to clear or rebuild the PDF Export plug-in registration? Any guidance would be greatly appreciated.
Thank you!
