Hello together
I would like to export PDF plans, but unfortunately this does not work in the Rhino 8 version. Does anyone know why? I would be very grateful for your help.
Best regards
Boris
Hi Boris -
I’d try a “Repair” on the Rhino installation from the Windows Control Panel.
Also please provide the output from the Rhino SystemInfo command.
Hello Wim
Thank you very much, I will try that.
Rhino 8 SR15 2025-1-19 (Rhino 8, 8.15.25019.13001, Git hash:master @ 74164bdf5469c2f269746857c54b8c44b74c7b24)
License type: Commercial, Build 2025-01-19
License details: Cloud Zoo
Windows 10 (10.0.19045 SR0.0) or greater (Physical RAM: 128GB)
.NET 7.0.0
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA Quadro M4000 (NVidia) Memory: 8GB, Driver date: 1-26-2025 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 572.16
- Secondary monitor attached to adapter port #0
- Windows Main Display attached to adapter port #1
- Secondary monitor attached to adapter port #2
OpenGL Settings
Safe mode: Off
GPU Tessellation is: On
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 1-26-2025
Driver Version: 32.0.15.7216
Z-Buffer depth: 24 bits
Total Video Memory: 8 GB
C:\Program Files\Rhino 8\Plug-ins\Tibidabo\VisualARQ.rhp “VisualARQ”
C:\Program Files\Veesus Point Clouds For Rhino 7\Veesus.rhp “Veesus Point Clouds for Rhino” 4.3.8075.17901
C:\Users\Workstation\AppData\Roaming\McNeel\Rhinoceros\8.0\Plug-ins\SpeckleRhino2 (8dd5f30b-a13d-4a24-abdc-3e05c8c87143)\SpeckleConnectorRhino.rhp “SpeckleConnectorRhino” 2.19.0.15137
C:\Program Files\Rhino 8\Plug-ins\Tibidabo\Tibidabo.rhp “Tibidabo”
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.15.25019.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.15.25019.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoRender.rhp “Vorgänger Rhino-Renderer”
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.15.25019.13001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.15.25019.13001
C:\Program Files\Rhino 8\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 8.15.25019.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.15.25019.13001
C:\Program Files\Rhino 8\Plug-ins\Grasshopper\GrasshopperPlugin.rhp “Grasshopper” 8.15.25019.13001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.15.25019.13001
I have carried out the repair. Unfortunately, it still displays the same message.
Hi Boris -
When you disable those plug-ins in the Rhino Plug-in Manager and then restart Rhino, does that make a difference?
I deactivated the plugins and restarted Rhino. Unfortunately no results. I also activated all plugins, but unfortunately that didn’t help either. Rhino PDF and Micro Station DGN were the only ones that could not be activated.
C:\Program Files\Rhino 8\Plug-ins\Asuni.Ifc.Export.rhp “IFC Export Plug-in (V3 Engine)”
C:\Program Files\Rhino 8\Plug-ins\IFC\IfcImport.rhp “IFC Import Plug-in (V4 Engine)”
C:\Users\Workstation\AppData\Roaming\McNeel\Rhinoceros\7.0\Plug-ins\Vectorize (4c63f2be-7c08-4c8b-8186-a24d29c69bcd)\7.0.8438.18098\Vectorize.rhp “Vectorize” 7.0.8438.18098
C:\Program Files\Rhino 8\Plug-ins\Asuni.Ifc.Import.rhp “IFC Import Plug-in (V3 Engine)”
C:\Program Files\Veesus Point Clouds For Rhino 6\VeesusRender.rhp “Veesus Point Cloud Renderer for Rhino” 3.3.7611.23546
C:\Program Files\Rhino 8\Plug-ins\SolidTools.rhp “Volumenkörperwerkzeuge”
C:\Program Files\Rhino 8\Plug-ins\import_3MF.rhp “import_3MF”
C:\Program Files\Rhino 8\Plug-ins\Export_FBX.rhp “Export_FBX”
C:\Program Files\Rhino 8\Plug-ins\MeshFromPoints.rhp “PolygonnetzAusPunkten”
C:\Program Files\Rhino 8\Plug-ins\RhinoScriptEditor.rhp “RhinoScriptEditor” 8.0.23161.1000
C:\Program Files\Rhino 8\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 8\Plug-ins\Import_FBX.rhp “Import_FBX”
C:\Program Files\Rhino 8\Plug-ins\import_DGN.rhp “MicroStation file import: import_DGN”
C:\Program Files\Rhino 8\Plug-ins\import_LWO.rhp “Lightwave-Import”
C:\Program Files\Rhino 8\Plug-ins\Import_glTF.rhp “Import glTF” 8.15.25019.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 8\Plug-ins\import_VRML.rhp “VRML-Import”
C:\Program Files\Rhino 8\Plug-ins\RhinoBonusTools.rhp “Rhino Bonus-Werkzeuge”
C:\Program Files\Rhino 8\Plug-ins\export_3MF.rhp “export_3MF”
C:\Program Files\Rhino 8\Plug-ins\export_X.rhp “X Exportieren”
C:\Program Files\Rhino 8\Plug-ins\RhinoLabsTools.rhp “Rhino Labs-Werkzeuge”
C:\Program Files\Rhino 8\Plug-ins\export_RAW.rhp “Raw Triangles Export”
C:\Program Files\Rhino 8\Plug-ins\export_STL.rhp “STL-Export”
C:\Program Files\Rhino 8\Plug-ins\import_AMF.rhp “Import_AMF” 8.15.25019.13001
C:\Program Files\Rhino 8\Plug-ins\import_SLC.rhp “SLC Import”
C:\Program Files\Rhino 8\Plug-ins\import_DST.rhp “Import_DST” 8.15.25019.13001
C:\Program Files\Rhino 8\Plug-ins\export_ACAD.rhp “AutoCAD file export : export_ACAD”
C:\Program Files\Rhino 8\Plug-ins\AnimationTools.rhp “AnimationsWerkzeuge”
C:\Program Files\Rhino 8\Plug-ins\IdleProcessor.rhp “LeerlaufProzessor”
C:\Program Files\Rhino 8\Plug-ins\export_LWO.rhp “Lightwave-Export”
C:\Program Files\Rhino 8\Plug-ins\export_WMF.rhp “Windows Metafile Export”
C:\Program Files\Rhino 8\Plug-ins\export_VRML.rhp “VRML/X3D-Export”
C:\Program Files\Rhino 8\Plug-ins\Squish.rhp “Ebnen”
C:\Program Files\Rhino 8\Plug-ins\export_OBJ.rhp “export_OBJ” 8.15.25019.13001
C:\Program Files\Rhino 8\Plug-ins\export_AI.rhp “Adobe Illustrator Export”
C:\Program Files\Rhino 8\Plug-ins\export_XGL.rhp “XGL Export”
C:\Program Files\Rhino 8\Plug-ins\import_M.rhp “Import_M”
C:\Program Files\Rhino 8\Plug-ins\CreaseAngle.rhp “FaltenWinkel”
C:\Program Files\Rhino 8\Plug-ins\export_points.rhp “Punkteexport”
C:\Program Files\Rhino 8\Plug-ins\import_OFF.rhp “OFF-Import”
C:\Program Files\Rhino 8\Plug-ins\export_SKP.rhp “SketchUp Export”
C:\Program Files\Rhino 8\Plug-ins\export_POV.rhp “POV-Ray-Export”
C:\Program Files\Rhino 8\Plug-ins\Tutorials.rhp “Tutorials” 8.15.25019.13001
C:\Program Files\Rhino 8\Plug-ins\import_PLY.rhp “PLY - Polygon-Dateiformat Import”
C:\Program Files\Rhino 8\Plug-ins\import_ACAD.rhp “AutoCAD file import: import_ACAD”
C:\Program Files\Rhino 8\Plug-ins\import_STEP.rhp “STEP-Import”
C:\Program Files\Rhino 8\Plug-ins\ShrinkWrap.rhp “ShrinkWrap” 8.15.25019.13001
C:\Program Files\Rhino 8\Plug-ins\export_RIB.rhp “Renderman Export”
C:\Program Files\Rhino 8\Plug-ins\digitize_MicroScribe.rhp “MicroScribe-Digitalisierer”
C:\Program Files\Rhino 8\Plug-ins\export_STEP.rhp “STEP-Export”
C:\Program Files\Rhino 8\Plug-ins\QuadRemesh\QuadRemesh.rhp “QuadRemesh” 8.15.25019.13001
C:\Program Files\Rhino 8\Plug-ins\export_IGES.rhp “IGES Export Plug-in” 8.15.25019.13001
C:\Program Files\Rhino 8\Plug-ins\export_SAT.rhp “ACIS-Export”
C:\Program Files\Rhino 8\Plug-ins\export_wamit.rhp “WAMIT Export”
C:\Program Files\Rhino 8\Plug-ins\import_IGES.rhp “IGES-Import-Plug-in”
C:\Program Files\Rhino 8\Plug-ins\export_VDA.rhp “VDA-Export”
C:\Program Files\Rhino 8\Plug-ins\import_X.rhp “X Importieren”
C:\Program Files\Rhino 8\Plug-ins\import_RAW.rhp “RAW-Dreieck Import”
C:\Program Files\Rhino 8\Plug-ins\NamedPositions.rhp “Benannte Position”
C:\Program Files\Rhino 8\Plug-ins\import_OBJ.rhp “Import_OBJ” 8.15.25019.13001
C:\Program Files\Rhino 8\Plug-ins\export_SLC.rhp “SLC-Export”
C:\Program Files\Rhino 8\Plug-ins\import_GTS.rhp “GTS-Dreieck-Import”
C:\Program Files\Rhino 8\Plug-ins\Import_PDF.rhp “PDFReader”
C:\Program Files\Rhino 8\Plug-ins\Walkabout.rhp “Walkabout”
C:\Program Files\Rhino 8\Plug-ins\export_UDO.rhp “Moray Export”
C:\Program Files\Rhino 8\Plug-ins\import_SCN.rhp “NextEngine Import”
C:\Program Files\Rhino 8\Plug-ins\MeshTools.rhp “PolygonnetzWerkzeuge”
C:\Program Files\Rhino 8\Plug-ins\export_GTS.rhp “GTS-Export”
C:\Program Files\Rhino 8\Plug-ins\digitize_Romer.rhp “Romer Digitizer”
C:\Program Files\Rhino 8\Plug-ins\Calc.rhp “Rechner”
C:\Program Files\Rhino 8\Plug-ins\import_WAMIT.rhp “WAMIT Import”
C:\Program Files\Rhino 8\Plug-ins\Export_glTF.rhp “Export glTF” 8.15.25019.13001
C:\Program Files\Rhino 8\Plug-ins\export_XAML.rhp “export_xaml” 8.15.25019.13001
C:\Program Files\Rhino 8\Plug-ins\export_SVG.rhp “Export SVG” 8.15.25019.13001
C:\Program Files\Rhino 8\Plug-ins\import_STL.rhp “STL-Import”
C:\Program Files\Rhino 8\Plug-ins\import_VDA.rhp “VDA Import”
C:\Program Files\Rhino 8\Plug-ins\import_SKP.rhp “SketchUp Import”
C:\Program Files\Rhino 8\Plug-ins\export_PLY.rhp “PLY - Polygon File Format Export” 8.15.25019.13001
C:\Program Files\Rhino 8\Plug-ins\export_CD.rhp “Cult3D-Export”
C:\Program Files\Rhino 8\Plug-ins\export_GHS.rhp “General Hydrostatics (GHS) Export”
C:\Program Files\Rhino 8\Plug-ins\RhinoCode\RhinoCodePlugin.rhp “RhinoCodePlugin” 8.15.25019.13001
C:\Program Files\Rhino 8\Plug-ins\export_DAE.rhp “Export_DAE” 8.15.25019.13001
C:\Program Files\Rhino 8\Plug-ins\Import_SolidWorks.rhp “Solidworks-Import”
C:\Program Files\Rhino 8\Plug-ins\export_X_T.rhp “Parasolid-Export”
C:\Program Files\Rhino 8\Plug-ins\digitize_Faro_Titanium.rhp “Faro USB-Digitalisierer”
C:\Program Files\Rhino 8\Plug-ins\import_GHS.rhp “General Hydrostatics (GHS) Import”
C:\Program Files\Rhino 8\Plug-ins\export_AMF.rhp “Export_AMF” 8.15.25019.13001
C:\Program Files\Rhino 8\Plug-ins\export_CSV.rhp “Export Durch Kommas Getrennter Werte”
C:\Program Files\Rhino 8\Plug-ins\import_E57.rhp “E57-Import”
C:\Program Files\Rhino 8\Plug-ins\import_points.rhp “Punkteimport”
C:\Program Files\Rhino 8\Plug-ins\BlockEdit.rhp “BlockEdit” 8.15.25019.13001
C:\Program Files\Rhino 8\Plug-ins\MPlane.rhp “MEbene”
C:\Program Files\Rhino 8\Plug-ins\import_SVG.rhp “Import_SVG” 8.15.25019.13001
C:\Program Files\Rhino 8\Plug-ins\export_3DS.rhp “3D Studio Export”
Hello everyone
Does nobody know a solution? I mainly need Rhino PDF to display the layers in the PDFs. As already mentioned, everything works in Rhino 7.
Best regards
Boris
